I changed my diff oil using Castrol Synthetic LSD oil (got mine at supercheap) you need 2 litres (takes about 1.6) at $30 odd per litre.
Diff is quiter and car slides more predictably well worth the effort. Fill and drain Plugs came out OK, you will need a oil gun to pump in fluid.
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-545173
duncan, iv'e the old unlimited diff problem as well, actually should make it an unpredictable unlimited 'ish' slip diff :D
what kind of info have you got on diff replacements? only thing ive seen was the upgraded one from UAS, but at $1200 exchange it looks a little too expensive at this point in time!!
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546201
I've found myself a second hard, v tight diff for $500.
Unfortunately its from a non-abs car, apparently they just unbolt the centre and wack it into my car.
If you don't mind a tight diff, call importers and wreckers, and ask them if they have a diff that a customer hated and made them change back to stock :D
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546242
true, good point!! will look into it when i get some dosh, will make a bit of difference on the track, way to much spin out of the corner!!
would there be a difference in the abs and non abs diff's?? mines non abs, do you know what kind of difference that would make on the track, mostly is if you actually locked up, or do they brake better in general?
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546276
The difference between ABS and non ABS equipped cars is the sensors on the housing for the rear driveshafts (I assume Skylines have 4 channel ABS?) that measures wheel speed, or lack of in the case of it being locked.
So if you dont have ABS then no point getting an ABS diff as it wont equip your car with ABS without all its sundry items.
My diff is noisy as hell, oil gets changed regularly with Mobil, but makes no difference to noise.
Any oils out there that are renowned for shutting things up?
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546317
found out little about my new diff today, its a full 1 way race item :D
I'm just getting the centre swapped into my diff, it came of a skyline with 4 channel ABS (sensors on the half shafts) whereas mine is 3 channel with sensor on the driveshaft
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546656
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
