Well as you know i have run a bearing in the GTR.....
I reali have a few choices.....
Im trying to save for a house and really at the moment thats the most important thing....
So i can rebuild the enigine.... $10,000....
I could try and sell the car as is.... What would it be worth? Leaving the wheels, power Fc etc etc etc?
I could strip the car get it back to standered and sell it? Whats it worth then?? And then sell the parts serperate?
Or lastly i could get a rb26 engine for 3000 and put it in my self and sell it... Whats it worth then??
These are just ideas at the mo.. Just tossing up what to do....
Then id get a cheaper car around $10,000 as a daily
Help
https://www.sau.com.au/forums/topic/256567-need-some-advice-what-do-you-think/
  • Replies 54
Strip parts, new RB26 put the work in and put your parts into new rb26 and sell the old one for cheap, or keep it incase you need to use other stuff off of it. But a cheap daily for like $2k while all this is happening if you don't already have one
I have a whole list of parts thats only done around 1000kms if that...
SARD injectors
Power FC and Controller
Jun Cam Gears
Greedy Profec 2 Boost Controller
Brand New in Plastic Nismo Fuel Pump
Work Xd9s 18 x 10 Brand New Tyres
HKS boost Gauge
Pod Filters (or Standered Air Box)
Thats just the stuff i could replace for standered
Edited by Adz2332
depending on size, bout $1000 SARD injectors
$1300 Power FC and Controller
$250? Jun Cam Gears
$350 Greedy Profec 2 Boost Controller
$250? Brand New in Plastic Nismo Fuel Pump
$3000 at least Work Xd9s 18 x 10 Brand New Tyres
$150-200? HKS boost Gauge
$100-150? Pod Filters (or Standered Air Box)
thats approx 6k - 6.5k worth of parts!
there 700cc injectors
But yer it is roughly that sort of cash in parts...
so if i was selling the car for 24,000 get 6000 for parts get back 30000.....
have to out lay right now around $4000 to get an engine but it in and replace back to standered parts tune etc...
and have a few other little things,
Second blank GTR key,
Brand new Greedy Strut Brace
Brand new Greedy Radiator air guide
Carbon N1 wing
GTR Carbon end caps
Full Exhaust system
Edited by Adz2332
yeh id just slap another rb26 in there, the car is worth bugger all sold with a dead donk. like has been suggested, replace with stock rb26, sell off all good parts from your dead motor and that will more than cover costs
well i am looking for a greddy front strut brace
and i would rather help a fellow sauer out...you know what i mean
wont be much but will be something
so first dibs on the strut brace
:huh:
if you ever think about owning a GTR again you will potntialy still have the same problem, and no matter what engine you buy it'll still have the same design flaws unless you fix it... so i say fix this one up if you still want to drive an import, otherwise, sell it and buy some non-turbo local car =P
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
