  • Replies 49
with aftermarket gauges, what should it normally read?
need to work out wether my sensor's farked...
I assume your asking for temp? If you have a Power FC + commander you can compare to the stock one.
Usually around 70-80degrees which is under halfway on the factory gauge @70degrees celcius...
A lot of other people run 80-90 degrees which is probably half way or past half way on the standard gauge, which I hardly ever look at so I'm just guessing here :(
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4420817
thanks
Hi there
160~180 deg F is about ballpark for lite use. (160~180)-32*(5/9) for deg C................. (degC*9/5)+32= Deg F or yoostabe, back in the bad old days.
You need a known good sensor to isolate source of error.
Find/steal/borrow known good replacement sensor & place (whilst still connected to your wiring harness, ignition on~ might need extension lead knockup) in cup of ice cubes floating in water, 60/40 mix, for 0~4 degC check of gauge, place in cup of boiling water for 95~100deg C. or there abouts. If ya want to get serious place a thermometer in reference liquid.
Alternatively you could plug your display into a mate's motor/temp sensor arrangement & verify your gauges.
Cheers GW
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4420831
My defi reads, 85 or so on regular driving and just above 90 on hard driving. Lcimate will play a big factor as well and also what coolant you're running, I run Texaco extended life and I am thinking about switching to Red Line Water Wetter.
Edited by TriniGT
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4423167
Stock thermostat is 76.5C.
Normal Operating temperature in the region of 82C.
Boiling point of most systems, 110-115C.
Stock dash temp. gauge is useless, half way (few mm either side) ranges from ~60C - ~95C, you won't notice it moving until you've already hit 100C.
Just below the top of the gauge for me is 104C (only seen that high once after a few big burnouts).
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4423612
85 - 95 for me up here in sunny north qld
where its hot all the time
Yeah mines about the same Pedro, microtech hand controller displays about 85-90. I've seen it over 90 a couple of times when giving it a bit during the day.
Gotta love our heat lol.
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4424350
Man i've got it good, runs about 75-80 depending on weather and up to 85 with hard driving in brisbane in summer.
I don't have air con though so that helps get some more air into the radiator.
Interesting :P I am removing my aircon condenser and receiver/dryer soon and putting a pair of thermos where they used to be along with some splitters/guides
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426396
i Dont think the water wetter is such a good idea in an rb. It does not stop rusting of the block and eats away the water jackets over time...... Cost me a whole Fuc&in engine!!!
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426515
Use it as an additive on the street, running it pure with just water would only be recommended for track use.
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426648
the standard ecu and powerfc keep the timing a little retarded and richen it up a little until water temp is 80deg or higher
half way on the stock guage should be 80deg
interesting. myne usually sits at 75-77 and only ever goes higher if thrashing it on a hot day (highest its ever hit is 81). got a pfc and i doubt it would have been over 80 when it was tuned, might explain a few things
https://www.sau.com.au/forums/topic/256602-water-temp/#findComment-4426864
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
