  • Replies 49
My front end isnt as cluttered in a HR as other models i think, plus my I/C setup is nothing like most FMIC are its close to the radiator core where as you look @ some FMIC's right down the front, making the air go all sorts of places, where the air only has one place to go with mine
Well, thats my theory on it anyway
Mine sits steady on 81c have seen it as low as 79 on a brisk morning and the highest has been 85c with spirirted driving/tuning. All of these readings were on my PFC hand controller.
Microtech dash tells me between 84 (winter) to 88 on a 47 degree day with a bit of spirited driving, it seems to hit up to 92 when the car's parked with the motor running for an extended period, but thats the highest I've seen it go, and thats with a leaking water pump! Quite impressed with it given that it's a JDM car with a small radiator being in often very hot conditions here
  • 10 months later...
My old 180 was the best, she'll be sitting on 95 most days, that's with a twin core GT-R radiator and 3 thermos... good ol' RB in a S13 chasis.. LOL.... overheat Queen!
your conservsion was shit than, my rb in the s13 while thrashing thru the hills on a hot day struggles to go past 86, cruising on the highway during the day it sits comfortably on 80-82, cruising on the highway at night time, 78-80, after steady night driving for a while and gunning it up to 200 than backing off i've seen the water temp drop down to 70 than slowly climb back up to 78-80
highest its ever been was 110, but that was a fairly long static skid!
Interesting thread.
I'm currently looking at trying to reduce my water temps, and it sounds like reducing the clutter in front of the radiator is the key.
I will take out all associated air con bits, but is there anything else I can do?
Today on a 38 degree day in Perth, on a free flowing highway going 100km/h in 5th, the water temp got to 95 on the PFC hand controller, and 102 on the Defi which reads from the top of the radiator.
Stock gauge didn't move.
^ i couldn't have more infront of my Radiator if i tried
I have
1x A/C Condensor
1x Ally Radiator
1x Small thermo fan/LH side - thats gotta be doing fk all compared to the clutch fan other than blocking air
1x Unchopped front bar, not much airflow on a HR31 bar
I have no issues on hot days. IMO i have more clutter than anyone else does.
The key is a good radiator and the clutch fan. I'm assuming that my motor sitting a bit lower is perhaps having some advantage - NFI how/why though hehe :blush:
Perhaps better 'guiding' of the air is what you need, being mine is kinda cluttered - it cant actually get out the sides and is being forced down the middle as there is little room for air to get out around the sides of anything
Interesting thread.
Sounds like your waterpump isn't functioning properly or your radiator is blocked.. When was the last time you had
your cooling system checked and serviced
I have
1x A/C Condensor
1x Ally Radiator
must be a hr31 thing, i cant get my car above 75.
what radiator you using brockas? still got the clutch fan and shroud?
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
