Ye maybe - mine sits super low... lol. I dont very high as stated unless its a stinking hot day!
That's using different temp sensors as well just to be certain none of them were stuffing up etc.
do you have your stock under shielding to help (air pressure in the engine bay IIRC), was reading something about this on the Datsun forums where overheating is more of a big deal lol
Nope - its all free underneath mine.
  • Replies 49
Sounds like your waterpump isn't functioning properly or your radiator is blocked.. When was the last time you had
your cooling system checked and serviced
Waterpump has been checked and is working well. Radiator flushed about a month ago.
Jonno, I'm using a Koyo 50mm aluminum radiator + clutch fan and shroud. After investigating today, I think my clutch fan may be shagged.
Will try another one and see if that helps.
No idea about 33's, but on a 32 the electric fan out the front is an engine exessive temp fan, can't remember when it comes on. You can bridge it to come on with the aircon, but you have to make wiring modifications for that to happen.
The last hot day I was out in mine, I was hitting about the same water temps as Brockas, everything in mine is stock though..
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
