I am looking at the Mines & Reimax cam cover baffles for the RB26's. The thing I can quite get my head around is physically how large are they? Does anyone have some approx dimension - particularly for the Mines ones. The Reimax equivalents appear to be much shorter.
Both are shown on the Greenline site if anyone is wondering where to look.
https://www.sau.com.au/forums/topic/256610-cam-cover-baffles/
ive fitted 5 sets of these...the most recent on Sunday. The Mines ones are longer and need to be drilled to clear the cam cap studs if you keep the baffle caps on.
I never drilled mine !
Did you move the baffle caps to the new position as shown in the instructions ?
cheers cokey
cheers cokey
do you have camp cap studs? or just the std bolts?
i think paul was referring to the aftermarket studs having to be clearanced
Just the std setup which are bolts for all but the 8 which hold the baffle caps they are studs.
Maybe Paul could post a pic of the drilling ?
When he has a minute,as he is busy preparing for new arrival.
Best wishes to stace.
cokey
cokey
yeah the ones ive installed all used cam cap studs...not bolts...so needed drilling.
new arrival?
Edited by DiRTgarage
  • 3 weeks later...
Anyone able to give a quick run-down of how to install these puppies? I picked up a set this week but came with no instructions (I know there are ones posted above, however I don't read Japanese) Is it a simple straight swap affair or do some modifications need to be performed?
  • 1 month later...
I'm wondering, would it be overkill to use both the Mines triple flow baffle plates, and a oil/air seperator at the same time?
I'm also wondering with the Mine's plates, oil purists here (not one myself, but hypothetically anyway); wouldn't you want the blowby oil that would normally come out the stock baffle plate to be caught by your oil catch can than a oil/air seperator or the triple flow baffle plates sending it back into the sump?
Check attachment if still needed the instructions
Installation_Instructions_for_Triple_Flow_Cam_Cover_Baffle_Plate.pdf
  • Like 1
Take em out , blank the breathers off and use a GZ vacuum pump , helps seal the rings better - reduces blow by -reduced and relieves crank case pressure - allows oil to drain out of the head quicker at higher rpm and increases hp - up to 50hp in some cases.Also helps keep oil cleaner if running a little rich in some areas. Good bank for buck.
do you plumb the pump into the back welsh plug where you typically plumb the head drain into?
what kind of vacuum figure would you aim for in the crankcase?
  • 5 months later...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
