I am looking at the Mines & Reimax cam cover baffles for the RB26's. The thing I can quite get my head around is physically how large are they? Does anyone have some approx dimension - particularly for the Mines ones. The Reimax equivalents appear to be much shorter.
Both are shown on the Greenline site if anyone is wondering where to look.
https://www.sau.com.au/forums/topic/256610-cam-cover-baffles/
ive fitted 5 sets of these...the most recent on Sunday. The Mines ones are longer and need to be drilled to clear the cam cap studs if you keep the baffle caps on.
I never drilled mine !
Did you move the baffle caps to the new position as shown in the instructions ?
cheers cokey
cheers cokey
do you have camp cap studs? or just the std bolts?
i think paul was referring to the aftermarket studs having to be clearanced
Just the std setup which are bolts for all but the 8 which hold the baffle caps they are studs.
Maybe Paul could post a pic of the drilling ?
When he has a minute,as he is busy preparing for new arrival.
Best wishes to stace.
cokey
cokey
yeah the ones ive installed all used cam cap studs...not bolts...so needed drilling.
new arrival?
Edited by DiRTgarage
  • 3 weeks later...
Anyone able to give a quick run-down of how to install these puppies? I picked up a set this week but came with no instructions (I know there are ones posted above, however I don't read Japanese) Is it a simple straight swap affair or do some modifications need to be performed?
  • 1 month later...
I'm wondering, would it be overkill to use both the Mines triple flow baffle plates, and a oil/air seperator at the same time?
I'm also wondering with the Mine's plates, oil purists here (not one myself, but hypothetically anyway); wouldn't you want the blowby oil that would normally come out the stock baffle plate to be caught by your oil catch can than a oil/air seperator or the triple flow baffle plates sending it back into the sump?
Check attachment if still needed the instructions
Installation_Instructions_for_Triple_Flow_Cam_Cover_Baffle_Plate.pdf
  • Like 1
Take em out , blank the breathers off and use a GZ vacuum pump , helps seal the rings better - reduces blow by -reduced and relieves crank case pressure - allows oil to drain out of the head quicker at higher rpm and increases hp - up to 50hp in some cases.Also helps keep oil cleaner if running a little rich in some areas. Good bank for buck.
do you plumb the pump into the back welsh plug where you typically plumb the head drain into?
what kind of vacuum figure would you aim for in the crankcase?
  • 5 months later...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
