Hay
Just having trouble with my boost T it will on go up to 6psi max any ideas why this is could there be a fault with the boost T where would the best place to take it and get it installed and how much they usually charge .
thanks
https://www.sau.com.au/forums/topic/256625-boost-control-install/
Could be a few things - missing the little ball inside the boost t? (is it brand new??)
You could have it installed in the wrong lines?
You could have changed the vaccume line and its too big now to control boost correctly etc.
Follow the DIY here on skylinesaustralia - its pretty straight foward... if you have any dramas pop me a PM and i'll see if i can give you a hand.
Dayne
I can have a look for you and install it if it's not installed properly. Won't take more than 10mins, unless you've done something funky.
The last time I helped someone install one, they decided to install it on a line to the Carbon canister.
Edited by StinkyPoo
When putting in a T peice as a boost controller and its fully open and/or closed depending on what type it is you can creat "overboost". Popps/splutters and lack of grunt can occur during overboost. Included is air/fuel ratio, do you have an intercooler and some of the other upgrade gear like zorst, filter etc..
However if you heard a loud "pop" and then heaps o smoke it is likely the turbs is farked.
Get a mech to confirm your issue. To be sure to be sure.
BTW - 7psi is stock from memory and 14-15psi would be max (straight through, no restrictions)
Edited by Sinista32
try the traders on the forums,
but you have
slide
nengun
justjap to name a few
I'd get a mechanic to check it first. My turbo blew just recently, you'd want to get the car looked at to make sure it is in fact the turbo. and not the engine as well.
Not a good idea.
Some of the Traders may have just removed a working turbo to replace with an upgrade. Be very carefull buying second hand from an individual. Have it checked out or buy one that has been is my advice.
Go to the For Sales on SAU and check out some posts.
Cheers S!N
PS. Yup Slide :D for good advice
Oh and you could get Garret in Fyshwick to check it out ($60)
Edited by Sinista32
Hay
tryed puting the boost t on through the diy it mad a pop sound and now is blowing smoke so i am now thinking that the turbo is f**ked so pissed off any ideas
By the sound of it you have incorrectly installed the bleed valve (boost controller) and may have blown the turbo...
1. When it made the "pop" noise, were you revving the engine?
2. What line did you install the bleed valve in and are you sure that you didnt put it in upside down?
3. Have you tried removing the bleed valve and returning the engine to near stock, then starting it?
Where abouts are you located in Canberra? - If you need someone to check it I may be able to help.
P.S. Do NOT buy a second hand turbo... If you do need a new turbo, buy a new quality branded product from a reputable dealer or you may regret it in the long run.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
