Hi guys, need some help. Bought this alloy intake pipe for my R34 Gtt off ebay. Went to install it and im pretty sure its the wrong one.
Contacted the seller and he is adamant its for R34 Gtt and he has had no complaints so far selling them.
Found a picture of another one (the blue one in the picture) which looks more like the one i need as the holes are in the right position. This one is also for an R34 Gtt.
So which one is the right one?
The one i Bought
The other one
https://www.sau.com.au/forums/topic/256631-angry-and-confused/
  • Replies 42
Posted Images
I also once did this same thing years ago, I was stubborn, persistant and lucky, I eventually got my money back. I new the seller was also trading on SAU and the Silvia site, so I contacted the forum mods for both sites and reported him as a bad trader. I did the same on ebay. He eventually caved in and made good, but it took 8 months to do it. I sent my purchase back and asked for a refund within 1-2 weeks of receiving it, so he had my $$$ and the goods for 8 months.
I suggest you try doing the same, you will win out if you reach nuisance level. You shouldn't have to put up with shoddy goods.
Irony was that they began a group buy not long after I'd bought my reject, I would have never gone through with it if I'd known about the group buy.
Good luck.
thanks for the replies
Yeah its a chinese one. He has advertised as it fitting R33/R34 and Stagea.
But that blue one in the pic is also advertised for R33/R34. Which ones which?
Ill see if i can get my money back.
Anyone know where i can get a alloy or s/s intake pipe for R34? I asked an exhaust shop to do me one but he said it requires a fair bit of work and its better i buy a ready made one.
Edited by Jay777
Hi Gents,
It will work if you rework your exisitng BOV and PCV return pipes.
The problem with using steel for this pipe is that there are the two return pipes that go in very close to the turbo inlet, and are much much easier to make in rubber/plastic as they can be moulded.
The two pipes that go in are actually steel, so in order to make the item you bought work, you must cut back your existing steel BOV/PCV pipes and fit silicone extensions to them to hook up with the two pipes coming out the side of this.
Hence, why the silicone ones are much much easier to fit, and work just as well as the steel ones.
I had a mate with the same problem as you. Bought a hard intake pipe for his S15 to replace the factory rubber item. Was advertised to be a direct replacement.
Turned out to be a direct replacement item.......once you replace other items. A few hoses and lines would need to be replaced with longer ones, and the actual pod position wasn't fantastic either.
Same deal, stubborn dealer didn't want to take it back, insisted it was a factory replacement regardless of the photo's proving him wrong. In the end he took it back and refunded. Took some doing though.
they arent a direct replacement for either the r33 or the r34. they're meant for you to make custom return lines from the BOV and the breathers. i like it because it means getting rid of the crappy metal piping for these which looks ugly. also means i can plumb in a catch can without having to plumb the return there. AND i can install a BOV somewhere else in the cooler piping and have it plumb back without having to use the standard piping.
bottom line is its not for you if you are afraid of a little customising and cleaning up your engine bay.
just thought i'd raise this question, but how did you expect a STEEL intake pipe to be a direct swap when the BOV and breather hose return pipes are also made out of metal? how did you expect them to join? or did he advertise that it was made of magical fusing metal also? i mean, you must have looked at the photo and said - hang on, that wont work no matter what, even if the fittings WERE in the right spot.
Good ole ebay strikes again with its attractive cheap price to match its poor quality.
Next time buy from trusted traders on this forum and you wont have a problem
They generally are not as cheap, but thats because the gear is decent
there was nothing wrong with the gear. the item was never going to fit no matter what. its a direct replacement in terms of where it sits and the stock air filter location. i'd like to see a steel intake pipe that still uses the stock return BOV and breather piping.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
