Im looking for a good cheap first car. Im looking at spending 2k or less for a daily driver until i can save for something a bit nicer later down the track. Im in SA and would like some advice on what a good car would be. Im a big skyline fan so was considering a R31.
Suggestions?
P.S manual car only
Edited by dblstR
https://www.sau.com.au/forums/topic/256646-first-car/
Is there any common issues with R31s i should know about when looking for one? Price difference between turbo and non turbo?
You'll only be able to afford the Aus built RB30 R31's, not a turbo model if you've only got 2K.
Diff whine is common in the R31's not a major issue but common, check for rust and the tyres been used. The R31 is fine in dry weather, just not the safest in wet weather unless you've got good tyres.
The silhouette model is the top of the range manual but has a premium on it...it also had LSD from memory.
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4422738
you wont get turbo for 2k
common issues are AFM, CAS and the ignitor thingo
otherwise fairly reliable :D
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4423208
for my first car mate i got a camry
then later on upgraded to a S4 RX7 and now a R33 Skyline
the whole point is that get something reliable for that price...
since your on your P's mistakes are bound to happen mate and you will learn a lot that way in case of driving
then when your on your Full license...2 years time or so then upgrade to a nice turbo and with a relatively clean record you will be able to do alright with insurance as well...
good luck with it all mate
hope this helps
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4423727
To be honest though a Ford KA-KE laser are one of the best little tampon taxi's you can get.
A few mates (including me) all brought a few of them and not one of us had any running issues with em and drove them 110% everyday of the week and the only thing (out of owning two) that died was a start motor which really wasnt a big deal because you can virtually get in the engine bay yourself to changing it is easy there is that much room
They loved being flogged hehe, good economy too!
I remember taking mine down the Great Ocean Rd here... considering its twisty and limited to 80km/h you could push it to the limit and still not loose your license as it didnt have the balls to accel upto 90-100, but you could throw it into a 40km/h corner @ about 60-65 and just laugh as it screeched all the way around
Dont get an auto one though, manual for sure, much more fun :P
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4424460
i would highly recommend a Corolla SX or GTi. You will find them in that price range, My one has near 300,000 k's on original engine and still doesnt blow smoke. Still happily spins to 7500 rpm and will totally decimate your carby 6 banger Commo and Falcons...Yet cruising will still get 500+km to a tank of fuel 40 litre tank as well. I would stay clear of the Skylines until you can afford the one that you really want. Otherwise your just going to spend money doing it up when it really isnt the car you have your heart set on.
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4424905
Fun cars i have owned for under $3000 off the top of my head:
1987 Prelude 2.0i
1988 Accord 2.0i
1991 Integra LS (I think it was, hell fun car, insurance was pricey)
1985 Civic hatch (I actually want another one for an engine conversion)
198* Lancer hatch (basically an early mirage)
Can't-remember-the-year Alfa 33
A Alfasud (electrics caught fire during the night - however I did buy it for $300 while building another car)
1991 Laser (that thing was a FWD rally car made out of granite, mithril and hardened weetbix by the dwarves of middle earth loved it, crashed it, pop the bumpers back out with a heat gun and a gentel persuader, repeat)
N13 Pulsar Vector with LSD option - hilarious car
what else? Well of the R31's, Falcons and Commies I have driven in this price bracket they were mostly nowhere near as fun as the front wheel drive 4 bangers. Mostly in way worse condition for the money too.
Edited by R33_Dude
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4429572
I strongly suggest R31 all the way!!!
I had that as my first car and owned it for 8 years!!! Very sad when I sold it - if I could have afforded it and had somewhere to keep it, as well as my new R34 I would have definately kept it!!!
Personally I love the Ti Models
Beautiful/comfortable interior
Full elects, Cruise control
they were all auto - unless it was converted (like I did with my one :D )
Some had LSD - if you want it you can get it done, dont know how much it costs these days, it cost me $550 back in 2001
If you get the Series 2 (1986,87) - its the same transmissions as the VL's had (only difference in then manual is 5th gear to the VL)
The Series 3 (1988,89,90) Auto is different - its Electronically controlled ( I was told its the same auto as what the 300ZX and some Patrol's had)
They are fine as long as you look after them and service them when needed
Cant do Shift Kits on them ( I was told anyways ), the older Auto's you can.
Don't do Nuetral to Drive 'rev n dumps' coz that kills the Auto pretty quickly as I learnt :D (was planning the manual anyways)
Common issue i've found with them is the power steeing lines sometimes leak fluid, and the steering rack under the car, check for oil leaks.
Once they get to the high 200,000k's you might need a new water pump
Check all the bushes, tie rod ends etc.... normal wear and tear that comes with the age of these cars.....
You might have a few oil leaks from the Roccer Cover - sometimes easily fixed with a tightening of the screws with a screw driver, easy.
Apart from the two above, you wont have any issues if you dont drive it as hard as I did alot of the time.....
My parents still own a Series2 which they've had since 97 - still going strong.... driven it everywhere, including upto QLD and back to Melb.
If you drive it normally, service it every 10,000k's, if you drive it hard, every 5,000K's (just oil and oil filter), and I guarantee you that engine will be bullet proof!!! spark plugs approx every 15,000k's or so......
they dont rattle and squeek like a Crumbledoor, and dont leak oil like a old Falcon.
Electrics are the best you'll find in a car that age - window's dont take 10years to open and close like a VL Calais
with My Series 3 Ti
Auto with only 2.5" Exhaust and pod filter - got 91rwkw
once converted to manual, same mods - got 98rwkw
I bolted on a t3 Hi-Flow, intercooler, VL turbo Injectors, etc pretty basic setup - got 127rwkw on 7spi
then with extra injector and 10psi - 165rwkw in 2003
When I bought it in 1999 it had 226,000 I sold the car in 2007 - still on 10psi new owner put it on the dyno - still had 164rwkw
and that engine had over 300,000k's, Engine Never opened from Factory, completely untouched!!!!
My point to all the above!! I think the R31 Skyline is defiantely one of the Best Cars ever Built in Australia!!!!!
Reliable, Powerfull, comfortable etc.....
Only reason I broke stuff on mine in the early days is because of the way I drove it..... which goes for any car if driven hard
one day When I can afford it - I will own one again built for track purposes only!!!!
Ohh, for price diff these days check out www.r31skylineclub.com
I know i'v rambled on abit but yeah..... R31's ROCK!!! :)
Edited by FULOCK
https://www.sau.com.au/forums/topic/256646-first-car/#findComment-4436009
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
