Hey Guyz,
I have an R33 GTST.
I installed an El Gauge dash kit, which turned out really good. However, after re-installing the dash and all, I noticed that I couldn't start my engine! When switching the ignition on just before cranking the engine over, I can hear a really continuously loud buzzing noise from the front of the car. When I try to crank the engine, I get a really loud ticking noise. The engine doesn't crank over at all, just makes that damn strange noise. Also, when switching the headlights on, the stereo loses power for a few seconds and then comes back on.
I checked my fuses and they all appear to be fine. Originally, I thought that perhaps I might have a wire that isn't earthed properly, so I disconnected the El Gauge kit and removed it completely, but still no luck! I removed the stereo, but I still have the same problem!
I have checked all wiring for a mistake somewhere, but everything seems to be good.
The first time I tested it, everything appearing to be perfectly fine, I even cranked the engine over and that worked perfectly fine. After re-installing the dash, I got these problems.
Does anybody have any ideas???? Please help or give me any suggestions that you might have....I'm desperate!
Regards,
Nick
https://www.sau.com.au/forums/topic/25665-engine-wont-start-help/
try jump start it. i have had to do this a few times in the past.
make sure you only use a good set of "anti-zap" leads so as not to cause any electrical problems.
maybe even a push start if your car's manual. taking it then for a good drive might be enough to brin the battery back to life.
hey guyz...
i've got the same problem, i've read this thread b4 so i went to change the battery. But still its doing the same problem. Engine wont start and its still gettin that clicking noise when i'm trying to star the engine. Sorry this isn't for the R34, its for the supra. can some1 really help out on nefing else wrong with the car besides the battery?
The car is stuck at home and i cant bring it to any mechanic, and i wouldn't think anyone would come besides towing it.
So anyone help out plzzzzzzz..... i really need some help.
the car is a 94 model non-turbo supra. No mods.
had a situation possibly similar!! but mine started for about 2 seconds then got that clicking and it stalled!!
Turned out it was the points on the ECU and relays in the boot of my R33, reason was there was a build up on them after having the car not moving/started for 4 months!!!
cleaned up the points and away she went, although had stalling issue for a while after that but all fixed now (give it time)
hope this helps!
CharlieR34,
This isn't me talking but I think this might help if you havent already seen it:
In most cases, the solution to this common Mk3 problem aren't nearly as severe as the cost involved with starter replacement. A clicking starter means that the high current necessary to start the car isn't making it to the starter for some reason.
Battery cables, chassis ground straps, and fuses ‹ Sounds trivial, but any loose connection can prevent sufficient current to flow to the starter. This is the first logical (and inexpensive) test to perform.
Starter safety switch ‹ Your car has a safety switch to prevent unintended starting of your engine. For a manual transmission, this is the clutch switch, and automatics have a neutral/park switch. To check their operation, try holding the key in the START position and push in the clutch (or move the auto tranny shift knob from park to reverse). You should here a definite click under the dash (by the glovebox) and under the hood. If not, your safety switch is bad, or the starter relay under the dash is bad.
Magnetic Switch (solenoid) Contacts ‹ After checking 1) and 2), you probably have bad magnetic switch (solenoid) contacts. This is a common problem with older Mk3's and is easy to remedy once you've got the starter out. Symptoms of this problem include clicking sound from both under dash (relay) and under hood (solenoid), and inability to start when cold or when very hot (heat soak after long trip). Try Toyota part #28226-72010 Starter Kit (each kit contains one contact) and replace them in pairs. Total cost is about $11.00 (Jay Marks Toyota 7/98) and can be replace in a couple of hours (see Tech Notes).
If none of these three are applicable, you probably do need a new starter.
(Sourced from http://www.supras.com/sogi/faq/)
MEGA
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
