I have the same thing.
Now as far as my understanding goes (and dont quote me on this, im sure someone can shed some more light on it) but it loops the powersteering system to trick the car into thinking its complete as you bypass the hicas system.
Is this true?
I had a quick look the other day (I still have to get a lock bar so im in no rush) I think it loops the system right near the powersteering canister.
Or am I completely wrong?
'just looked on a 300zx site and there is an identical part in the "instructions"
this part actually goes up where the front solenoid is after you remove it????????
thanks for the helpfull advice
at least know wtf you are selling! and where the f**k it goes
end rant
YES!
Thats what I was trying to explain without very good results.
If you end up stripping the entire system could you write up a lift of what was removed from where?
And rough weight?
Cheers mate,
Cris
Mate i did away with the whole lot right back to the power steering pump. Everything got turfed. lines solonoids actuators, the lot. I even pulled the power steering pump out and pulled it apart and took the hicas impeller out. Actually playing around with an old one atm to ditch the whole rear section of the pump, machine the shaft and match the rear cover. All i've done for the moment is i've machined a bush to replace the banjo fitting on the pump to stop the oil from coming out. It's dimentions are 26mm OD 16.5 ID and 16mm tall. Probably cost 30 buck from a machine shop. :P
theres a long thread on hicas removal. sydneykid uploaded a lot of images & instructions. your fitting is maybe a replacement where he loops a hose
evocoop: howd the low speed handling change on your car with the hicas removed?? thinking bout doin the same, vept the pump part
mike
Edited by Mike__
mike
I haven't actually drivin it yet. Still building it. Gotta be a good thing but cause it elimimates a variable is how i look at it.
Alls i did was buy a hicas lock bar from Just jap and made this little bush and chucked the rest in the bin.
  • 1 year later...
so did anyine find out where this jjr bypass actually go. i just got one, i have installed the lock bar and tried to fit the bypass to the rear solenoid but it definatley doesnt go there, i havent checked the fron solenoid or power steer pump yet, i ran out of daylight
I have just recently been through this. Installed the lock bar and removed lines back to the fail safe solenoid which is on drivers side in front of rear wheel.
Found that the JJR bypass would not fit at this point so looked at all other lines and fittings. Would not go anywhere else so removed the fail safe solenoid and took it to JJ.
Sure enough the problem was they had a batch manufactured that are inncorrect. They gave me another one and I test fitted it on the spot. Worked a treat.
Cheers,
Steve
Cheers,
Steve
I had the same problem a few months ago. I couldn't get it to fit, assumed that I wasn't installing it in the correct spot so I sold it. Now looks like I had it in the correct spot but the part was manufactured incorrectly.
I should write them a letter to get a refund or replacement. Most likely I will just end up buying another one.
I was scratching my head for ages thinking what are the chances that it almost fits in that spot but belongs somewhere else on the car.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
