i spoke to just jap today, they said they had a bad batch a while ago, now they think i have a 300zx one instead by accident, i need my car this week end so i cut mine in half, grinded it to make it the correct shape, turned down the brass spacer/washer and welded it back together in the correct spot, gonna test it all out tonight,
i also noticed the lock bar is shorter than the original steering rack and when i tried to get the toe correct by eye i only have 3 threads left, no way im gonna drive it like that, so i pulled it all back apart and have made some 14mm spacers where the inner tie rods screw into the lock bar, this should give me a safe thread engagement now and get the toe correct safely,
just jap are sending me a different bypass on monday so when i recieve it i will let you guys know if it fits
  • 1 year later...
sooo, anyone get to the bottom of this, i wanna do this shortly
bypass kit http://justjap.com/s...184&cat=&page=1
BTW: does the R34 NEO powersteering pump with single outlet work as a replacement (along with bracket)?
Edited by BWRGTR
If you're talking about putting a Neo pump onto an R32 engine.....no. The hoses are completely different. It's an Enzed/Pirtek job and whatever $$ is costs you to buy the other half of the hoses if you don't have both already. I had to do it to put the Neo into my R32.
More to the point. If you're putting a single stage PS pump in, then you do not need to loop the HICAS lines. Just pull all teh HICAS stuff out and throw it in the bin. That's the rear solenoid, the engine bay solenoids, and some of the pipework. You just keep the stuff that goes from the pump to the rack and reservoir, and find a way to plumb a cooling loop/cooler in place.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
