Just dropped in a 68k Rb26 with HKS 2510 turbos into my 32 gtr. She started up really easy idled really really rough and blew alot of white smoke. This finally cleared so i guess it was just oil from the engine sitting around for a long time.
Heres the current problem. It is really really slow to free rev takes ages to get to even 4k. Stabbing the throttle does stuff all compaired to my old rb20.
Taking it for a test drive tomorrow to see how it goes.
Now I know there is one problem the CAS was loose. We have set the timing to where it idles the best and tightened it up. Want to get a timing light on it but cant see how with the coil plugs.
Any ideas on setting timing and the possable problem?
https://www.sau.com.au/forums/topic/256730-new-26-just-dropped-in/
you can still use a timing light to find the base timing id say its either CAS or maybe the timing belt now put on properly possible skipped tooth?
Where do you hook the timing light up too? i doubt its skipped a tooth on the timing as belt is well tensioned and was not removed being a 68k engine it should be due for replacement yet.
Taking ages to spin up is probably due to timing too retarded, so that maximum combustion pressure occurs after TDC. Using a timing light on RB-series engines has been covered numerous times.
Did you get the injectors cleaned before you installed the engine.
... Running some injector cleaner through it with the fuel. ...
Pretty much a waste of time, if the injectors are already dirty. And if the engine has been sitting around for a while, who knows what condition they are in?
Run a HT (conventional coil lead) lead between the coil pack and spark plug and clip the timing light on that.
Timing gun attached and working. Just need to be 100% sure about setting the timing.
Idle at 950rppm timing should be set to 20deg BTDC
From left to right what does each mark represent? I think i have it done right but just want to make sure.
Have searched through the gtr service manual but at 300 pages i haven't found anything yet.
Cheers for the help
Details are shown on page EN-11 of the genuine service manual......28 pages in from the start of the manual (well, it is in my electronic version)
Don't know how I missed that part. OK Timing set now. Issue with coil pack fixed and she now seams to be running alot better.
Al tho its now blowing a heap of white smoke when i give it a bit of throttle. Smells like oil burning. Could it be oil in the cooler pipes from the old engine?
  • 1 year later...
May as well update this even tho car is gone.
White smoke was from a massive build up of oil in the cooler pipes from the old engine.
Engine problem was due to dodgy silicon joiner that would only open up under boost. Car ran perfect after this.
Edited by Crans
  • 2 months later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
