Rb26 Shuffling Turbos, Overfuelling And Map Sensor Imbalance.... Related?
G'day all,
Tried ripping off the pods and hard pipes and went the open compressor intake for a quick trip around the block. Paul, mate, you were onto somehing... I honestly thought that it would only affect AFM driven rb26's.
I couldn't believe it, but it actually made a huge difference! Still shuffles at idle and a little when backing off the throttle when cruising, but otherwise spooled nicely with no audible shuffle at pretty much all throttle openings other than ~closed. Throttle response and low/mid range torque is dramatically improved. I put the pipes and filters back on and it was there again as bad as before.
Now that's all good, but I can't drive around without filters on it... wouldn't like to guess how long the donk would last. I measured the hard pipe lengths and they ended up being pretty balanced.
Does anyone know how to sort out the intake piping issue? Should I go for the concertina style plastic piping to introduce turbulence and avoid reflected reversion pulses from the hard pipes?
Do I need to invest in a freer flowing pod apart from these "DRIFT" pods?
Should I try and put a "balance pipe" between the two intake hard pipes?
The lengths are already balanced so that can't be the only variable.
I have discovered an/the underlying problem of the shuffle. The issue with the shuffle is that the turbo's are simply trying to flow too much air for the engine to swallow at idle/light throttle at cruise and it is banking up behind the throttle plates and when the pressure becomes too great (doesn't take much at the idle condition with the low exhaust velocity) it escapes back through the compressor wheels and inlets. I stuck my hands in front of each inlet and as it shuffled you could feel the flow reversion back out the inlet... in fact, even when it wasn't shuffling at idle, both turbo's still had long periods of air flow back out the inlets.
It's clear that I need to either try fitting the stock recirc valves (and get that leakback effect) or find some other way to bleed air at vacuum and into boost transition.
Does anyone know if I could change the compressor housings to reduce this flow reversion problem? I have heard of anti surge housings which pretty much have slotted bypass holes at the compressor housing inlet. Will that help at all?
Wow wat a read!
The rear housings must be quite small, and the front wheels quite large to be 'breathing' on idle.
I had a similar issue on a mates SR20 where it was chuffing on idle and was screwing around with the afm. Was running a very small rear housing and being coupled with a large front comp housing it caused this problem.
Just some intell on a similar situation, but obviously only single turbo.
If you fit standard GTR BOVs in the system, it should help, they actually open on idle, so you would think it would give the air thats bouncing around in there somewhere else to go..
Im really surprised CRD couldnt find a solution to your problem!
GTR BOV's and the leak @ idle helps alleviate this further as stated, along with the stock flex/rubber piping and seems you should never have any surge.
Good to hear the theory about surge & hard pipe kits proven in the real world once again ;)
Gotta hand it to factory Nissan in that respect. Whilst it doesnt look nice, it works.
Its hard to say, a balance pipe between the hard pipes might well work... Trial and error continues? :rolleyes:
Anti surge comp housings work similar to the BOV's i believe letting some air bypass/take a different path into the turbo.
I think Disco posted a pic very recently about how the flow goes actually. It could work... however its a lot of effort when GTR BOV's could be a faster/easier option.
If you need a set of GTR BOV's i have some :ermm:
just my experience:
with twin gt-ss on a 25, i was shuffling ridiculously everywhere like a train while these turbos would be pretty much fine in a gtr.
I however had custom cooler piping at around 2- 2 1/2" diameter and snakey inlets to a single pod filter (1 AFM) and Trust BOV wound up tight.
so.. It seems this is the worst case scenario and what you would do to promote shuffling
Currently have 3 inch or larger cooler piping everywhere, 3" turbo intakes to a huge pod each, NO BOV at all and thing runs like a dream. Still "blows off" the pressure in two stages when i let off the throttle, but does not chuff in vacum or anything like before.
To me this means that larger piping everywhere has an effect. Either it is because of the restriction or simply because you have a larger damping area for what is probably still occuring. My original plan was based on the two turbos having different inlet path lengths etc. especially as they were both through the 1 filter
worked for me anyhoo
If you had agood mappable ecu with spare outputs could you not add a re circulatory solenoid controlled BOV valve that leaked plenum air at the offending load / boost / throttle sites? I know it's a crutch, but haven't heard of this being done on the RB engine before.
Wow wat a read!
I had a similar problem on my RB25DET, front compressor wheel is too big for the exhaust, why'll my turbo does spool up fast and give strong boost through the rev range, it did surge. (making 220rwkw on automatic, 13psi)
The problem was fixed by taking off the GFB bov and fitting the stock RB25DET by pass valve. – Letting air bleed out rather than bounce back off the throttle body.
I've read the stock valves are meant to open on idle and plum back-in in front of the compressor wheel, the circulating air actually helps the turbo spool up faster.
Edited by daxter
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
