Fu(k these comparisons are stupid.
A fair one would be to get a v8supercar and a stock v8 SS current model. See the difference in lap times there. Then a stock GTR and a race prepped one, then see the difference.
The one with the smaller gap would clearly be the better road version of a race car.
  • Replies 52
Well my friend they were comparing v8 super car times with gtr times, the super cars use slicks and weigh less and have 600hp or so, the gtr has less hp more weight and road tyres so if you put the v8 super cars on road tyres and had similar power I doubt they'd be 18 seconds a lap faster!
Here's an interesting video which compares a VYSS Commodore, A9X and V8Supercar around bathurst.
It looks like the VYSS did a 2:51 (driven by a V8SC driver) so that might give some comparison with resect to how much quicker the R35 is vs an actual commodore road car - stock for stock. About 25 seconds.
I know the comparison is a bit silly, but did anyone stop to think that this was probably the most readily available data that they had...............
True, i suppose it makes for an entertaining read anyway.
Has anyone been keeping track of the bathurst production car race this weekend? Perhas those times are better for comparison sakes. Whilst they are "production" cars they generally have a good setup, dedicated for the track. A standard R35 would easily be in front, let alone one with rubber, brakes, cage (interior gone), seats, tune, etc etc.
18 seconds is an eternity on a race track.
In that article they list the pole times for all the bathurt's races, and you'll see that even cars from the 1970's were faster than the GTR.
Keeping in mind of course that the track was slighty different back in the 70's as the chase didn't exist until the second half of the 80's.
^^^touche
the GTR still fails as a race car in standard trim, and there aren't many cars out there that are ready from the factory for racing, so i still think it's pretty impressive.
What's not impressive is the weight of it, and it is unexcusable for it to weigh that much.
It's because it's so much more expensive than anything else that Nissan sells, but when compared to it's competition (which it beats), it's a bargain
No its much more expensive than anything else Nissan sells IN AUSTRALIA. Pretty sure the R34 GTR wasn't too far off that figure at one stage...
Most aussies when they think of nissan, think of the Tiida, pulsar, and maxima, and maybe a handful of 4wd's, so you can hardly blame them for associating nissan with relatively cheap cars for the average consumer. But what they dont see is the performance car heritage Nissan has - which is well known in Japan, but not many other places.
As for the comparison, the GTR is a factory road car, not a race car. I thought it came pretty damn close in cornering speed on most corners, and was even faster on one of the corners (was that correct?).
I think a race-spec GTR would find the extra 18seconds and then some, pretty easily.
The V8 supercars are pretty much just a shell, and completely custom - almost nothing about them has any resemblance to the road cars. So with this in mind a race-spec GTR would be much lighter, more powerful, and have better brakes and suspension setups. Its not difficult to imagine record-breaking times from a race-spec GTR.
However, I doubt we'll see the day...maybe an unofficial lap time perhaps, but not an official race one.
Those who complain about the weight - why? Its a road car - its already extremely quick...why sacrifice anything that it has when all you'd gain is more speed/handling? - and it performs brilliant in these categories already.
I reckon if the weight isn't hurting it, then its fine. Its a road car primarily. Any race versions would undoubtedly be much lighter...
Some of you guys should get out on a racetrack, or get out at Bathurst on a no speed limit event. A 2:25 is honking around there, for a STOCK road car.
The fastest Carerra Cup cars were running 2:20s at the Drive Bathurst event, and the quickest time that won the Supersprint was a 2:26 on the final day which was a R33 running in 2WD. None of those cars were even remotely close to standard.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
