Hey,
Planning on installing GTR injectors into my rb20 this weekend and wanted to know how straight-forward it is.
Ive been reading up a couple of threads but majority of them are cluttered with useless jibba-jabba :D
Ive read the best way is to remove the top part of the plenumn to get easy access to the injectors.
Ive purchased the following from a Nissan Dealer; Are these the only gaskets needed?
N1617553J00 Gasket - Throttle Chamber - $18.00
N2378540F00 Gasket - AAC Valve - $3.40
N1403272L01 Gasket - Intake Manifold - $13.60
My injector cleaner workshop said to place grease around the rings when pushing the injectors onto the fuel rail. Ive heard some grease can eat rubber? Which grease is best to apply to create a tight seal.
Does anyone have pictures of where the GTR Resistor pack was fitted in the engine bay in their r32 rb20?
Anyone have photos of the wiring to the resistor pack and any tips on how to easily determine which wire?
Also any other tips / hints when installing gtr injectors :)
I'll update this thread after Saturday with some progress pictures to help people in the future.
edit; Ill be doing the work in wheelers hill, victoria. If you've done the wiring before and are willing to give us a hand, please PM me :yes:
Thanks
Patrick
https://www.sau.com.au/forums/topic/256804-gtr-injectors-in-rb20/
i mounted mine on the opposite side above the brake booster, so it was away from any extra heat,
i also replaced my injector wiring plugs with some new ones as the rb20 ones are slightly different to GTR ones but with some filing they can fit, this was also cause the old plastic had turned a bit brittle over age and another thing the new ones had a spring style clip so you didn't loose the little wire retaining clip.
You should use vaseline as the lube for your o rings,
The power wire from the resistor i just took strait to the battery but installed a fuse in the line, this also give a good decent 12'v for you injector power
and as soon as you strip the insulation off the injector wiring the wires become a bit more obvious, and you don't have specific wires out of the resistor to join to specific injectors as long as you join all six wires to each injector.
I dont think you can but them separate.
you can get the coil pack loom separate
AFM/injector etc i think is full loom only, i could be wrong but i know AFM is full loom only... ripe pain in the ass.
Full loom is only $770 though, i know as im buying one tomorrow :)
Decided to try and put in the injectors this weekend. Some tips for people doing it in the future.
- Much easier to install injectors if manifold is pulled off.
- No need to pull off throttle body, leave it attached to manifold and just remove the cross over pipe etc
- There is 12 bolts holding the manifold, 6 you can see easily near the strut tower, the other 6 are deeper under the manifold.
- Manifold gasket will rip when removing manifold, and will need to scrub it off (took me 30-40mins with a razor blade)
- With manifold pulled off, easier to remove the fuel rail and old injectors.
- 3 injector connectors are on main loom and another 3 are on a smaller loom connected by a plug to the main loom.
- GTR injectors wont fit onto the rb20 injector connector's because the gtr injectors have 2 extra plastic notches.
- Can either trim off the notches or order GTR injector connectors from Nissan (As you wil be cutting the power wire from each connector to wire in resistor ballast, may as well just wire up new gtr connectors)
Here's a picture of what im up to haha
Will update later with resistor ballast wiring.
Cheers
Ok. This is slightly off topic but here goes.....
I bought a set of GTR injectors for my RB20 and I was told that they have been modified to RB20 ohm.
Is this feasable or has someone just told me a load of bullshit???
If is is possible, how can this be tested?
Thanx.
Cheers
Don't you mean plenum (or Nissan terminology, "collector"), rather than intake manifold?
You don't need to pull the manifold off.
cheers,
sam
Thanks for help.
Did you buy your injector wiring plugs brand new? Any idea on what Nissan would charge for them?
cheers
Nah mine were generic ones from a shop in Hobart called Automotive Service Solutions, i'm guessing there would be a place similar to this where you are
http://www.efi.com.au/index.php
yeah. my mechanic supplied me with some generic connectors which are perfect fit on the gtr injectors.
Also my rb20 plugs were all rusted inside and green from corrosion! One of them had barely any connection.
In order to wire the resistor ballast, i first tried to determine which 1 of the 2 wires to each plug was the voltage (which connects up to the other 2 plugs through the loom)
By setting the multimeter to resistance and putting the probe in one of the injector plug and then into the second injector plug you can search until the value on the screen shows 0.8~
This means that there is a resistance because both of them are connected somewhere inside the loom.
Hopefully that makes sense, ill try revise it after i get my car running :thumbsup:
Okay, i made this quickly in MSPaint, hopefully it will be easier to explain.
Basically, you can work out the linked connections without stripping apart the whole loom.
Just use a multimeter to try and find a closed loop. Also by using the 12v going to the loom (injector 4,5,6) it saves the hassle of stripping the main loom to find it.
Will have car put back together tomorrow and hopefully it will all start. haha
Hopefully the below makes sense
Cheers
  • 10 months later...
Oki pulling up an old thread due to talking about the same stuff in another topic which had nothing to do with it!
This is properly the smart way to do this and most likely will be doing it soon!
Q1: How much did the gasket cost that you ripped? do you have a part number?
Q2: How much is the ballast resistor? can we get some pics? so i can just go to the jap wrecker local and grab one ?
Q3: What did you use as lube for your seals? did you go with the Vaseline?
George :thumbsup:
George :D
Q1:
Purchased from Nissan Dealer. Took a day to arrive.
Q2:
GTR Resistor ballast
Justjap sells brand new for $210
http://www.justjap.com/store/product.php?productid=17524
Chop the plug off, and you will have 7 wires. (6 injector wires and 1 power wire, which is probably the yellow colour one)
Q3:
Are you talking about the injector seals before pushing them onto the fuel rail? I cant remember what I used. When i picked up my cleaned injectors, the person mentioned something to use but I have forgot haha
Hope the above helps.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
