hi all got a few things to get rid off its taking space its spares from my build up i will also have a few more items soonish well when i can be bothered picking the stuff up from my mechanic.
all parts have come off my R33 series 2 sedan turbo.
call me on (Allan 0401409575)
item 1 : Full R33 intercooler kit pipes everything brackets good condition $300
item 2 : Hard pipe from tb comes with standard r33 rb25det s2 bov $60
item 3 : s2 pink sticker AFM with pod perfect working order $150
item 4 : R33 s2 RB25DET Splitfire Coils Pack's Excellent working order i used them for not even 3 months $320 SOLD
item 5 : r33 induction pipe standard with b.o.v return piping perfect condition $60
Picture's
post-39600-1234437313_thumb.jpg post-39600-1234437365_thumb.jpg post-39600-1234437445_thumb.jpg post-39600-1234437486_thumb.jpg
post-39600-1234437525_thumb.jpg post-39600-1234437555_thumb.jpg post-39600-1234437593_thumb.jpg post-39600-1234437666_thumb.jpg
Edited by R334door(s2)
https://www.sau.com.au/forums/topic/256807-fs-a-few-spares/
ill take the intake pipe and return lines... take $50?
item 5 : r33 induction pipe standard with b.o.v return piping perfect condition $60 SOLD
https://www.sau.com.au/forums/topic/256807-fs-a-few-spares/#findComment-4423237
i also have 2x stock standard boost solenoids for R33 $15 each
also will have a bottom end soon rb25det s2 comes with crank rods pistons the usual short block standards
but in parts thought i blew the engine but it was the turbo main seals welcome to have a look
when i pick itup. $$ price not certain at this stage make a offer whats a short block worth these days.??
R33 s2 auto trans with stage 2 shift kit perfect, $$ price not certain at this stage.
auto r33 s2 impul ecu--boost cut moved rpm limiter moved a smidgen and 180 cut off removed suit 3" exhaust etc usual stage 1 mods got dyno sheet if you wish to have a look $200
gizzmo ebc $$ price not certain at this stage
front castor rod bushes to suit R33 sedan\coupe.$$ price not certain at this stage
https://www.sau.com.au/forums/topic/256807-fs-a-few-spares/#findComment-4423284
pm me back when you can i will put it away for you if you like.
https://www.sau.com.au/forums/topic/256807-fs-a-few-spares/#findComment-4424430
Would ECU suit manual?
not certain if the auto ecu would suit manual.?
also im not going to be on here for a few days so if people could contact me on (0401409575 Allan)
that would be great wont be around a computer for a couple off days.
cheers
Allan.
https://www.sau.com.au/forums/topic/256807-fs-a-few-spares/#findComment-4427634
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
