guys my steering has become quite noisy when I'm turning the steering wheel also there's sometimes what sound like a 'rattle' coming from the under the car somewhere in the steering rack/suspension region somewhere...
Its quite loud when the engine is cold in the morning etc. Last week I scraped the gutter with my 2 LHS wheels (at low speed ie. <10kph) and that's the only thing I can think of that might have done something.
I'm booked in tommorow at beaus repairs for a front and real wheel alignment but I'm not sure if that will fix it at all. What else can cause noise and feedback/vibration to be coming back through the steering wheel as you're turning it, esp. when cold?
Can gutter rash cause damage to steering rack or anything like that? Can a wheel alignment fix noisy steering ?
Edited by Delta Force
https://www.sau.com.au/forums/topic/256827-noisy-steering-when-car-cold/
I've uploaded a video of it to youtube at
and also at my internode web space (same vid): http://users.on.net/~sp23/MVI_0451c.avi
the exhaust is a bit loud and its hard to hear the whiny feedback noiseas I'm turning but its there if you listen to it closely as I'm turning the wheel. Also you can hear the very loud scraping/metallic rattle that also happens but not all the time (its noticable at the very beginning)
If you look at the vid ... good example of the loud scraping noise is at 0:15, 0:20, 0:24, 1:03, 1:34 and the steering wheel whining from 1:39 to 1:49 or so as I drive it thru the garage..
guys am I barking up the wrong tree with wheel alignment? should I even bother or instead take it to pedders to inspect the psteering pump, tie rods , wheel bearings and that sort of thing ??
________________________________________________________________________________
it seems not a day goes by without you posting some obtuse problem with your car - maybe time for a trade-up or enrol for mechanic school?
maybe we are becoming indifferent to your suffering (gee where did I see those words before ?)
lol
yes ! take it to Bearepaires or whoever in case there is a problem that may endanger the public when your out and about
yeah I checked the fluid ..seems to be in there, gonna take it to pedders see if they can put it up on a hoist and locate the issue. Yeah mr gray I'm getting sick of it too... if they were simple issues I'd suck it up but I get all these weird ones and it's not even a trashed car
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
