Not done it myself yet, but i believe that it doesn't matter how far you drill in (within reason) mainly because if you hit the water jacket, you just line the thread with plenty of locktight when you put it in. This is all off the top of my head and i have not researched it recently tho. Will be doing it myself again shortly.
With regards to the position, i don't think there is any measurable correct position. It's a tensioner, not an idler - so any slackness in the belt can be taken out.
There is only about 5 to 7 mm wall thickness in the block at the section you need to drill into. It does not matter if you go it to the water gallery as it will seal up when you put the stud in with loctite or sealant.
If it's within a certain area going of the manual that has been produce by ppl of this forum then you will have no problem.
There is 1 point that I can not emphasize enough, that is for the thread to be tapped straight and true so that the belt runs inline with all the pulleys and doesn't foul on any thing to detoriate the belt and cause premature wear.
i have a rb30 out of a series 3 silloette, just tapped the hole 16mm down from the head and 27mm in from the little 5mm hole, drilled in about 10-12mm and did not hit the water jacket, but if you do, use thread seal tape or even better, some hemp, lock tight will not work at all. it is best to tap it straight but if it is a little off, when you do up the tensioner it will pull it straight between the machined area of the block and the back of the tensioner. i used a 26 tensioners, not sure if it is different to 25.
  • 4 weeks later...
haha yeh word to that! i took so much time drilling and tapping my block and when i had finished, the tensioner had like a 0.2mm gap on one side wich made me freak out thinking my timing belt would jump straight off and drop valves... so i put a 3/8 deep reach socket over the stud ( once it was sealed in the block) and gently tapped it until it was straight. The ceff has done about 5000 k's now and it hasn't gone bang yet! : )
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
