Hi All,
Living in the UK we have a bit of a problem getting hold of RB30 parts. Is their anywhere i can get uprated/performance RB30E piston rings to fit standard RB30E pistons? Im have finally decided to see what i can get out of the standard pistons before upgrading to forgies later on (money restrictions really)
Can anybody point me in the right direction?
Thanks
Chris
https://www.sau.com.au/forums/topic/256836-rb30-piston-rings/
Hey bud,
I had this same problem not too long ago.. Drop me a pm and i'll see if I can sort you out.. Please confirm your engine type (RB30 non turbo? and the ring sizes you have.. ideally thickness and bore size if over std). always good to double check!
Regards
Lee
Hi Guys :)
Yes im using an RB30E block (none turbo) obviously with none turbo pistons. I plan to get the piston crowns and top ring lands Keronite coated and if i can get some decent piston rings it should improve reliablity. Leeroy, if you can help me out with that, it would be fantastic news chap :)
Im trying to get to around 8.5:1 - 9.0:1 compression ratio but im still clueless as to what RB30E none turbo pistons and an RB26DETT head with a 1.2mm head gasket, will give me in terms of compression ratio!
Leeroy, you have PM!
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
