  • Replies 67
from what i know injectors run out around 270rwkw!
LOL!! On what fuel pressure are you basing that on?
Just because the car "seems" fine, doesn't mean it necessarily is, AFR's and knock count will tell the truth.
from what i know injectors run out around 270rwkw! and im not running standard fuel system , ive got Walbro 255LPH , SARD Rising Rate FPR set to 33PSI on idle . I checked the plugs today that i put in last week and they are running rich , they are kinda black all over the tip . Also it backfires like crazy off throttle. So i dont know the ARF's but i will definatly keep it on 11PSI now all i was saying is it works on stock ECU , might not be safe but everything runs sweet though ( from a driving perspective ) not mechanically wise im sure
That seems pretty low for stock idle fuel pressure (std runs more than that - I think 3 bar (45psi). Injectors on stock run out around 215rwkw - depends on what you mean "run out" cause they will keep supplying fuel just not enough. Not enough fuel with more air = KABOOOMMMM !!!!! Busted ring lands on 1 piston the absolute minimum (cost for basic rebuild at least $4000)
Obviously (for a physicist or engineer) flow rates and therefore HP of injectors are based at a certain psi - (the only way you could possible give 1 figure), but they ramp up with more psi.
You would probably get around 240rwkw at 1 bar with your setup if it was tuned properly. This can be done with stock injectors if you want to have them running about 65psi of pressure (above atmosphere). Now if you were a damn builder how much extra water would you put behind a damn built for say 215mega litres? Because you injectors are like a damn wall at this piont.
band aid fix.
did you really think you could run a big aftermarket turbo with a stock ecu, stock ecu, stock afm and it would run good and make power?
do people not understand the idea of supporting mods; you can't make safe power with out enough fuel
my injectors were hitting 100% duty cycle at only 190rwkw on cold mornings. but you have an adjustable fpr so i guess you'll be fine..... :D
there is a world of
better response
better average power
better fuel economy
better overall
locked away in a new stand alone ECU or a complete remap
sure you can keep with the stock ecu and "it will work" but its not ideal
theres a massive difference between a complete tuned map and a piggybacked one
i was able to add in around 10deg+ on my std ignition map with the standard turbo
that drivability and how the car responds is amazing. this coupled with a complete turbocharger change, and youll have a pretty big difference
but piss and moan and keep with the stock ecu if you like
for the new guys reading, new to modifying your car this is how you smash your engine
buy a turbocharger kit thats much larger and plonk it on with std spec engine and std running gear
and expect it to work, turn the boost up and as long as its feels more poweful, its fine and nothing to worry
to upgrade from the std turbocharger to a safe a good setup you should have
stand alone ecu or remapped ECU (ask your tuner which one)
upgraded fuel pump (GTR is OK)
z32 airflow meter
injectors (500cc or higher, no hiflows)
clutch (heavy duty)
intercooler (any is OK, not SMIC, GTR is perfect)
a good competant tuner who can tune your selected ECU / remapped ECU
anything less is a comprimise and is likely to break the engine or put it at great risk
ballpark budget for this is at least $5k excluding the turbocharger
so if you think you can do it for $1200 go for it, but be prepared with "rebuild money" set aside
engines fail because
a) poor tune
b) lack of fuel, ie pump cant keep up, injectors maxing
c) no tune at all
d) owners screwing in more and more and more boost each time
e) excessive heat / detontation - poor tune, turbocharger working too hard, boost too high
yeah thats crazy, such a nice turbo but nothing to support it, you will need ecu and injectors then a tune and it will be fine, the way your running it, i cant see it lasting long, all it needs is the split second at higher revs for it to completly fail, will cost you alot more in the end,
ive just put a rb25 in my r32, i hate this R&R thing, it sucks, but im going to get a boost cut defender installed (apparently i can change volatage so i wont hit r&r), im only going to boost my car up to 13-14psi with this but i will still be putting it on the dyno just to be sure,
r&r is rich and retard. it's what the standard ecu does to protect the engine. adds more fuel and retards the ignition.
z32 airflow meter
clutch (heavy duty)
a) poor tune
c) no tune at all
and too much sand :(
z32 airflow meter
clutch (heavy duty)
a) poor tune
c) no tune at all
Very well said Paul. :(
dude, pretty much every1 here is saying the same thing to you. Its not because we think we're madk%^nts and don't want your car to be faster than ours, its because we have actually done research, had discussions with tuners/other owners and are generally well informed about the cars we have owned (in many cases for lots of years) and that we are passionate about.
We're only saying this for ur own good, so u don't blow a motor and end up having to folk out another 50% over the purchase price of ur car just to get it running again.
"You can take a horse to water but u can't make it drink"
+1 for sound advice in here, especially from the guys who've been around a while.
This thread makes me kind of scared now - I've got standard (i think) injectors with an aftermarket fuel pump and KKR pushing out 240rwkw, though the other day I did hit max cycle according to the microtech when doing a full throttle run in 3rd to program my Profec boost controller. Only happened once but it did give me a fright, might be some food for thought re getting some 500cc injectors, especially with my tune being rich as hell.
ok , here is one for all of you guys that said running a aftermarket turbo of the size that i'm running will not work on a stock ecu .. Not to piss in your pocket or anything but yesterday i decided to play around and just reset my ecu using the paper clip method and to my suprise it completly fixed everything i've been whinin about .. It now boosts FINE at around 15-16psi and pulls hard right to redline .. I've got no hesitation and no popping and everything is great car pulls harder then before and really has some torque .. I was at 220kw @ wheels with old turbo and i can really feel something around 250kw + .. Very suprised with my setup that everything that i have you guys deemed would not work but it does , i don't see the need to upgrade the air flow or injectors yet maybe for power later but i'm going good now , a power fc is my future upgrade but i'm happy with stock ecu and safc neo
lulz
even more lulz!
injectors run out way way before 270kw mate, i duno where your getting your facts from
My stock neo injectors (370cc?) were maxed at 260awkw so wound the boost down and making 240awkw barely safely for now.
It is a 3bar system but that doesn't include the vaccum or boost.. so 33psi at idle sounds about right..
my injectors were hitting 100% duty cycle at only 190rwkw on cold mornings. but you have an adjustable fpr so i guess you'll be fine..... :thumbsup:
RB25? wow..
looking forward to the next thread he creates
I just blew my engine = i am a f**ken idiot
+1
    • Cheapest option, find a NEO head. Put in good springs, decent cams, and send it to the moon. I rev mine to 8600RPM, gets me about 232km/h down the main straight at SMSP bouncing off the limiter in 4th. I've never dared to grab 5th 馃ゲ
    • Gday mate, Personally in my car i run 450kw in an s2 rb25 so also hydraulic lifters and have always run it to 7500 RPM and using some baby 256 poncams with new but stock springs and retainers. While i cant speak on any experience with solid lifters i personally have had no issues with my hydraulic lifters which were just cleaned and set in an oil bath before assembly over 7 years ago. Over 8k RPM is cool IMO and if you are using the stock gearbox or just a box with longer ratios the higher rpm certainly could aid to maintain boost into the next gear as that was always something i struggled with as i have a 3582r also but a hypergear equivalent could aid that issue. In summary i would make a choice on the cam you want to use first then decide which springs and retainers work best with it and then you can toss up if you really need the solid lifters, if the car is mainly street i would learn towards keeping the hydraulic lifters as when installed properly and nothing too hektik going on around them they do the trick.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
