I have to disagree with some of the comments made above.
I have standard suspension and can drift quiet well thank you.
"the best suspension is not going to make a great driver"
Skill, knowledge, control and practice are the key.
The best way to learn is on dirt in an open paddock/dirt, this lays a foundation that allows you to master the very basic's of drift.
When this is taken on the road this prepares you for what will happen when the car breaks traction, the increased grip forces you to fine tune throttle control amongst other things.
My car is also an Auto...............
I find knocking her to 1st for the tight ones and 2nd for all others is fine. Most drifting I have done is rarely above the range of these 2 gears.
A few of the fellow QLDers saw some of my work on Saturday night and will back me up.
1. Stock Suspension
2. Auto
Are not limiting factors
BTW loved the Vid Dr Drift, some more corner work and a little less 180's and it would have been a perfect Vid.
I agree totally, some of the best drifting was in my old datto 1600 with stock suspension...
As for the 180's the clip posted was more specific for the burnout action, much better footage from the day, but i don't have any posting space to put it, that was courtesy of meggala. That was not my choice of clip, I'll try and get him to post another up there...
Any video's of QLD drifters to back up your "I can drift an auto with stock suspension" claim?
Doc.
Guest Nismo_Freak
My 240SX cant drift very well... 3 degrees of negative camber in the rear w/ sticky tires and a N/a motor makes for short skids before tires catch and make for some interesting fish tailing. I have open differential by the way alond with a front tower bar and lowering springs. Im sure it can drift but my technique doesnt work and I dont like using the e-brake... seems too easy for me. Only way I can get a good slide is to go into the corner wide, turn in towards apex at 40mph, then I downshift hard into 2nd gear and it spins the rear wheel some and causes the weight-shift to sling shot the rear end out. It is very short lived and cant be maintained... possibly with some crappy tires but its very hard keeping the car from doing 180s or 360s with the open differential. In the rain the car is damn near impossible to drift as the car is too low... it pushes before sliding the whole car into a straightline skid. I am getting some Tein HE Drift Spec Dampers some time along with a LSD so that should make it a tad bit easier and alot more controllable.
Sounds like your going down the right track.
Had an opportunity to see two identical R32's on the weekend, except one had a tight LSD.
The Diff makes a big difference to sustaining a drift, and if you don't it can be a recipie for disaster....
Good Luck.
Doc.
for a controlable and impressive d0rift in an s13 (silvia/180) you want some fine suspension (tein coilovers, koni etc) some front/rear sway bars (large), front strut brace and a GOOD LSD!... single spinners are horrible!...
seriously i wouldn't try to fang a single spinner out sideways, its way too dangerous and hard to control. atleast get a LSD (2-way mechanical =) )
btw, power oversteer out of the corner isn't drift.
flicking it left then right well before the corner and having it sideways the entire time is =) and preferably coming out parrallel to the direction of the road you are turning onto. my definition anyway =) and to attempt at doing that on stock suspenion with a single spinner AND a n/a motor is truley asking for trouble.
skill can only go so far =) good suspenion just hides my lack of skill at this point =)
bolt on a turbo to your sr20de mate! buy one of my boards, retune him and away you go!!!.. i'm in the process of doing a 2nd conversion with oneone atm =) good results
I often drift on the way to work there are two corners that first is a right hand bend then the good one is a left hand bend with that slippery road surface that looks rough but is a light grey colour.. I'm sure u ppls all know it..
Anyway the stock suspension seems to handle it perfectly.
Sideways all the way through second I havn't tried 3rd as there is a nice stoby sitting there just waiting.
Also i do often use slight pressure on the brake just to get it hanging there that bit longer and it also causes almost 90degree powerslides.
3rd gear is dodgy with stock suspension i think.
  • 3 weeks later...
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
