Well it had to happen but the BP servo at main road glendale will be transformed in to a Shell/Coles servo so no more Ultimate at that location.
NOT HAPPY JAN
How ever there has been a bp open up next door to the Eagle Boys pizza store further down the road from the old servo.
Yes they do have Ultimate thank goodness.
Just hope it's the same quality
https://www.sau.com.au/forums/topic/256927-bp-servo-glendale/
but bp dont got none fuel voucher... if they did... i might go there.. shell does got a fuel voucher.. save a whole $2 mate.. dat buy you 2 pies at darbys .. or 1 pie at da servo your already at... aye bro.
yeah donno about up your way but down here the 4 cent discount is basically useless....
they make it look cheaper by dropping 4 cents, but they increase the basic price by 4 cents compared to mobil and independents anyway, sol it ends up being the same price anyway....
im pretty sure this has been discussed before...
shell and exxon mobil are the suppliers for the majority of the entire country. those two suppliers dont put different additives in their fuel for different end suppliers. its all the same stuff. british petroleum are the only "independant" type suppliers of fuel apart from shell and exxon (hence why ultimate seems to be the choice of skyline drivers). every other servo supplies the same fuel.
im pretty sure this is 100%. if its not - let me know.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
