Guys,
I've done a quick search of the forums and havn't found anything in relation to what the different headings and information etc. translation to!
If no-one here has done this I might start taking pictures of the screen and get them translated so I can post them up in their own thread so atleast people will understand some of it :)
Even better, can you have it switched over to English with new software in the SAT NAV (I assume from a thread I seen that it's the SAT NAV that drives the on-screen display thingie bob).
Anyways, if anyone has any helpful input let me know :) If not I'll wait until a bored day and I will start taking pics :banana:
https://www.sau.com.au/forums/topic/256936-m35-on-screen-navigation/
  • 2 months later...
Can you send me a pm too? Just got the Stagea and the buttons are more difficult to guess my way through than I thought! I can't even work out how to put the screen down. :)
To put the screen down, put your hand on top of screen and push down. It can tilt slightly so may need to line up correctly before it will go down.
The translation is being work on to make it English.
There are 6 buttons in the top row. The key button is the one 3rd from the right. This takes you to the main menu.
when there you will see a screen that has 6 selections. See the below link to see the english version.
http://www.skylinesaustralia.com/forums/So....html&st=20
I will be in Canberra nest weekend, maybe we should arrange to meet and I can show you through it, mind you it is pretty easy once you get used to it.
Cheers
Andy
Thanks. I did touch the screen and sort of felt like I could push it down but didn't want to in case I broke it :)
I found the button that takes you to the screen you can check out the fuel consumption etc. Kind of got lost with the rest. Stumbled across the radio one. I might buy my translator in law lunch and get her to write out some instructions for me. It'll be cool to see another M35 in Canberra as I feel like i'm the only one.
The last M35 you say in canberra may have been mine as I am down that way a few times a year.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
