hey all
few questions
well i got my fully built 25/30 back a few days back.. trying to get the engine and bow together before could but the whole lot into my cefiro and it just would not go, found out the internal diameter of the spigot bush was to small for the gearbox output shaft. so i removed the spigot bush all together.
but im wondering if it is complete a must to run a spigot bush???
like if i can ust not use one at alll and it should still be alright?
other question is iv dummy fitted my motor on its own and it fouls on the clutch master because of the forward facing plenum..
wondering how people have gone about relocating clutch master?
or at least how you get around this??
its a a31 cefiro with a built rb30det and rb 25t gear box.
be running around 360rwkw once run in and tuned..
cheeers in advance guys
tom
https://www.sau.com.au/forums/topic/256975-rb30det-woes/
already gone through 2 brand new spigot bushs..
they slide over the input shaft.
but once i tap it into the back of the crank its like they shrink so much that it cant slide in again...
doing my head in..
https://www.sau.com.au/forums/topic/256975-rb30det-woes/#findComment-4425488
using the soft wooden end of a broom stick to tap the spigot bushs in..
im using standard engine mounts but got a conversion cross member for rb25 box in cefiro off a mate along with the tail shaft needed for it to alll work.
with the gearbox siting on the ground i can slide the spigot bush over the out put shaft fair easyilly and smoothlly.
the fit in the back of the crank is tight as. and yeah once the bush is in its like it squiish's the bush size down so much that it cant let the out put shaft slide threw..
https://www.sau.com.au/forums/topic/256975-rb30det-woes/#findComment-4426474
i dont have access to a dummy input shaft at the moment. my old man lined the clutch plates up with a half inch driver handle.e we have tried adusting the cltcuh plates.. but thats when we figured out it was hitting the spigot bush instead of sliding into it
https://www.sau.com.au/forums/topic/256975-rb30det-woes/#findComment-4426523
where abouts did you get a dummy input shaft.
just wreckers or somthing??
we know it was deffinatly the spigot bush as it was being pushed back into the crank further.
If you know someone with a blown RB20 gearbox go take the input shaft out of that, pretty sure SR, CA, VG, FJ and L series can be used as well. Exedy sell them but when i installed my exedy hyper twin i used the one they supplied but it was a bit dodgy, it didn't align the clutch propley and i had to use an input shaft out of a blown gearbox i had.
How far in are you hitting the spigot? Does it look like the one below?
https://www.sau.com.au/forums/topic/256975-rb30det-woes/#findComment-4427418
yeah i was tapping my spigot bush in exact same distance into the crank...
hmm its hard where i am because im one of the few people in this town that drive an import.. so i have to travel about an hour and half each way to get to jap import spares in adelaide..
i have thought about getting another brand new spigot bush and cutting a thin slice straight threw on side. dodgy i know... i just wanna get this motor and box together
https://www.sau.com.au/forums/topic/256975-rb30det-woes/#findComment-4428399
I'll address the clutch master cylinder problem.
I picked myself up a new R33 GTSt clutch master cylinder for when the forward facing plenum and GT35R go on. The 33 item is about an inch shorter, my mate also used one on his 32GTS4 with RB30 and Greddy plenum.
https://www.sau.com.au/forums/topic/256975-rb30det-woes/#findComment-4430248
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
