  • Replies 123
Marvey Tech will still join us Matt and Daryll will talk about it and ill see him tomorrow, have to speak with Shaun and Troy, Chris from ACS will join us someone from NS with a +1 see >>Here<< will speak to Ric from auto perfection tomorrow
nah thats cos a sell MY ass on the street!
anyway, ill ring the Mawson Lakes and re-book a table for about 25?
lets see.
Steve
Damo +1
Nene +1
Heslo
PK
James
Scandy?
Krishy
Shaun
Luke +1?
Minibats
Matty
Andrew?
Jarrad?
Thats potentially 17 with more latecomers expected now the format has changed.
28?? any chance you could update Damo's list Patrick or Steve or anybody, lol
Stick me on it as well....just not sure about the missus as yet though
Dinner list so far:
Madaz
Damo +1
Nene +1
Weaksauce +1
Sled +1
pkblade +2
Jamesrb25 +1
Krishy +1
mid_life_crisis +1
Matty_31
Craig_R33 +2??
Evil34
muirsky +1
rad32
Minibats
nutstar +1 (NS)
Marvey Tech
i may have missed it steve but what time does it start ?
cheers dean
7:00pm
EDITED
Dinner list so far:
Madaz
Damo +1
Nene +1
Weaksauce +1
Sled +1
pkblade +2
Jamesrb25 +1
Krishy +1
mid_life_crisis +1
Matty_31
Craig_R33 +2??
Evil34
muirsky +1
rad32
Minibats
nutstar +1 (NS)
Marvey Tech
Auto Perfection +1
S13_Drifter
Adelaide Radial Tyres +1
Boostworx is a maybe +1 Troy may drop in anyway
Scandyflick - maybe
i still need to ring Bill @ ATS, Ryan @ ISC Performance, the boys @ Auto Pro, and Everlast
i count that as 38 so far :P
Neat casual dress, if you want to wear jeans by all means wear jeans if you want to wear a skirt wear a skirt and your girl can wear whatever also :blink:
its in the bistro guys not the function room
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
