when are you on full boost phil ???
Honestly i can't remember exactly (god it's been that long....). From memory in 3rd or 4th it was making around 16-17psi around the 4000rpm mark i think.
I'll tell you in a couple of weeks *fingers crossed*
I have been running the .82a/r GT3076R for a couple of years on my unopened RB25DET and I have definitely not got bored of it. From 4000rpm up she really gets a boogy on and even from 3000-3500rpm (after recently going for my first ride in a fairly standard ECR33) she doesn't really give much, if anything away to a stock turbo setup - it feels like it isn't pulling THAT hard until 4000rpm but thats more to do with how nuts it goes once it passes those revs than how much its lacking below there.
Its got a really progressive power delivery and have taken it for a few cruises around some reasonably tight windy roads and the car is very easy to keep on the boil, and to control how much "boil" you have. A GT2835/GT3071R would be a really good option too but I'd expect it to be working quite hard to make 290kw on a DD dyno from what some of the threads I have read imply, though really anything over 250rwkw makes for a very rapid car!
Mines the GT3076r with the AVO .73 housing
ive managed to pull 244kws out of it so far but that was with a stupid amount of boost leak (hose clamp)
but mines much the same as yours lithium pulls moderately to 3600-4000 then it goes pretty bloody hard from there to redline
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
