Doesn't surprise me, Top Gear Australia has to be one of the worst Car shows going around. I don't think they could have picked three worse presenters if they tried.
One of the cars in question....
Thats an mr2 with a ferrari bodykit
LMAO!
If thats one of the Ferrari's they used, then its 100% fake. It looks terrible!
I had a VIP backstage pass and at the end of the show, I was able to have a good look at all three of the "alleged" Ferraris. :D
Firstly none of the three had any red trim, so that photo is false, two had mustard and one was all black. :P
Now i don't profess to be a Ferrari afficionado, but they certainly had ferrari dials, large slotted rotors 355mm at least, large ferrari/brembo calipers,
rims had 5 studs not 4, they were all well and truely beaten up, with gaffa tape here and there and some shitty panel repairs.
The rear hatch/engine covers were opaque/scarlet in colour so the engines were'nt visible, but is that so unusual? So I'm not convinced
they were copies yet, a mate of mine took some pics so hopefully he has a few of the cars in question and if so will post.
Still they were not high on the ogle ajenda as the koenigsegg, R8, Gallardo, W427, promo girls, etc, were. :)
EDIT: but then again........clicky me for looky.
I should have made it a little clearer, I wasn't claiming that the picture I posted was the cars used on the day. Just a random picture of what they might have looked like.
from what i know, ferrari doesnt exactly like people to trash their cars... thats why they arent on gran turismo, ferrari didnt want them being crashed on a game, so i can understand if they said no to top gear doing that... they wouldnt even lend them an enzo to go round the track, they had to get a privatly owned one.. still they shouldnt be flogging them off as ferraris..
and my mate who knows little of cars had a ball.. and for all he knows they were genuine ferraris and he saw them doing burnouts etc. so he was stoked. i dont have the heart to tell him that they were fake... you could probably convince him that a straight mr2 was a ferrari.
at the end of the day... if your a car guru or atleast interested in cars enough to have some mechanical and general knowledge of cars... you'll know that you wont get anything out of going to see a top gear show.. its entertainment.. thats all.. its for the same kids that see an NA skyline with big wheels and get excited... but not knowing what the heck they are really looking at.
cheers
Linton
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
