1995 white 200sx damaged front end not drivable
pictures can be sent upon request
description
complete front smashed in with engine damage but other than that the rest of the car is in perfect condition for parts or if you wanted to fix it up. has a few parts like alarm, stereo, the interia is in perfect condition like new inside
looking to get rid of the whole car so make me an offer
looking for around $2500
https://www.sau.com.au/forums/topic/257048-damaged-200sx-s14/
hey guys thanks for the replys instead of sending you all pictures ill put them up so here they are. im still looking for around 2500 or with the rims 3500 they have all brand new tires on them, stero and everything on it, also has new brake pads on rear i only just put them on, and battery relocation to the boot and heaps of other stuff
hey sneaky um yeah what happen was it was pssing down rain and i was driving behing a big 4wd when he suddenly swerved out of the lane and unlucky me found a parked truck in the lane and it was to late to stop or swerve scariest thing ever just cruizing along under the speed limit and seeing all of the sudden when the 4wd sweverd a parked car, he must have not seen it till the last minute and i was left to take the impact
worst part is i looked after this car so much never drove it stupid never thrashed it always servised it best car i have ever owned used to take it the the snow all the time bah ohh well
  • 1 month later...
If it in Wa i will buy off it.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
