Meet Chuck,
global sensation and face of the "life less serious" campaign.
Over the next few months or so, Chupa Chups are running a competition in which you can win a Chuck doll.
I want one, for very irrational reasons.
So, SAUVIC, here's the scoop, buy chupa chups, find the winning stick for me and I will donate $500 to the charity of your choice and of course, reimburse your purchase price.
Cheers,
Matt
https://www.sau.com.au/forums/topic/257085-chupa-chuck/
  • Replies 42
I dont get it , is this "Chuck" suppose to be hard to get?
I cant find any info on the Competition?
Well, there are 1000 available, nationally.
So, it's relatively hard to get.
Info -
http://www.gotchucked.com/conditions.html
https://www.sau.com.au/forums/topic/257085-chupa-chuck/#findComment-4426353
might end up on ebay and you can buy it off them for 5 hundie.
will you reimburse us for all the other chupa's that we eat before we hit the winning one? lol. will have to keep reciepts.
I think ill buy one next time i see one....it has to be a competition marked one right?
https://www.sau.com.au/forums/topic/257085-chupa-chuck/#findComment-4426454
You are correct, sir.
Only the winning Chupa Chup will be reimbursed, but karma will reward you further in the long run :P
https://www.sau.com.au/forums/topic/257085-chupa-chuck/#findComment-4426458
Only the winning Chupa Chup will be reimbursed, but karma will reward you further in the long run :D
And you get to change your name to earl hicky......
For the price of a chuppa chup i would rather keep it.
https://www.sau.com.au/forums/topic/257085-chupa-chuck/#findComment-4426561
Haha. He is playing smart. 500 for 1/1000. Might be worth something in the long run.
Regardless. At woolies now and can't find any chupa chupps with the competition/promotion.
Im going to start living on chupa chupps just so i can win one and stir matt with it :D
https://www.sau.com.au/forums/topic/257085-chupa-chuck/#findComment-4426578
What a smart marketing move by the chupa chupp company.
Make a piece of rag that costs 20cents to make in a vietnamese sweat shop and looks like something you can find in the savlo bins a desirable limited edition model, and increase the sales of a solidifed ball of sugar and artificial flavouring not worth its wrapping paper. Accerelated 99% profit.
https://www.sau.com.au/forums/topic/257085-chupa-chuck/#findComment-4426692
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
