hi, tried a search, but it didnt answer my question
My power steering died last week in my R32 GTS, at first i thought it was the belt cos it broke about a year ago, it wasnt, then i thought it was leaking, it wasnt, so i tried changing the fluid twice, did not affect it.
Now im kinda thinking that it is the pump itself may have died, although ive never heard of anything like that happening in any car, I was also thinking that it could be the shaft linking the drive pulley to the actual fins of the pump.
Does anyone have any ideas about this, i will be removing the pump tomorrow to check it out, but if thats not it then im all out of ideas!
Sorry for the long post but this is starting to give me the sh*ts
Thanks in advance for any ideas/suggestions
Andrew
https://www.sau.com.au/forums/topic/25709-power-steering/
when u changed the fluid, did it take up about a litres worth, if yes then my guess is ur pump is working since it has filled up all the lines etc. wen filling up did u turn full lock left to right, wen u do this u shud hear the pump slurping and sucking away. this way u know it is pumping.
https://www.sau.com.au/forums/topic/25709-power-steering/#findComment-546257
yes, i did as u said, and was expecting (hoping) that i would get the results you described, but i only got about 300 mL out of the system, and was trying (with great difficulty) to turn lock to lock as i was filling, no luck there either. the other thing thats got me thinking its the pump is that i cant hear the pump when under heavy turning loads (full lock etc..)
thanks anyways
https://www.sau.com.au/forums/topic/25709-power-steering/#findComment-546265
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
