gazza750 Posted February 16, 2009 Share Posted February 16, 2009 this question always comes down to how much $$ u want to spend, and how much work u can do yourself.cheaper (as stated) to buy 2nd hand rb26dett. gazza- 15k for 450rwhp? hopefully 15 k should get that as stock i was getting 350 with just zorst and boost controller Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4428903 Share on other sites More sharing options...
autoworx Posted February 16, 2009 Share Posted February 16, 2009 with the exchange rate the cost of support parts is through the roof price up some new jap turbos , manifolds , fuel system and intake gear and you wont have much change left at all Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4429396 Share on other sites More sharing options...
bubba Posted February 16, 2009 Share Posted February 16, 2009 (edited) well awd adaptor plate is $900 + labour Fair call, but adapter plate labour isn't hugely significant in the rebuild process. + retap block for rb26 arp headstuds another $500 + labour For 400hp? + timing belt/tensioner kit $300 + labour Why? timing belts are <$50 and unless your tensioners are shagged you can reuse. + crank collar $150 + labour Fair call. (going by pro engines pricing) and any other nitty gritty things that you may need to fit a rb30 bottom end into a GTR So, I forgot about the adapter plate.. the adapter plate is the only significant difference between putting a 30 in a gtst or a gtr. For a basic build (400hp) I wouldn't bother with arp headstuds. Timing belts can be had a lot cheaper than pro-engines. Crank collar would need to be done anyway unless the guy was going to buy a 33gtr crank. I have been in a 4wd RB30 R32 and IMO the 3L goodness is worth the extra 1-1.5k. There's also a pair of -5's for sale which would go quite nicely on there Seriously, if you only wanted the extra torque and not looking to put huge turbos on there, the build could be done in a weekend if you know what you're doing and have access to the right tools.* *Providing you have all the parts ready to go. A workshop won't do it for you in a weekend though and would probably encourage a full forged build. Horses for courses, it all comes down to what you want to do with it and how much you want to spend. Just don't get talked into going overboard when it's not needed Edited February 16, 2009 by bubba Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4429512 Share on other sites More sharing options...
R32 Driver Posted February 16, 2009 Share Posted February 16, 2009 His being a 93 model GTR i assume has a wide crank drive already most engines this age are getting old and i wouldnt want to lose a 10k engine over a tensioner bearing or bolt etc but in saying that even a pair of -5 produces close to 500awhp then you have to lengthen the front pipe to accomadate the extra block height etc lil stuff adds up Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4429770 Share on other sites More sharing options...
bubba Posted February 17, 2009 Share Posted February 17, 2009 His being a 93 model GTR i assume has a wide crank drive alreadymost engines this age are getting old and i wouldnt want to lose a 10k engine over a tensioner bearing or bolt etc but in saying that even a pair of -5 produces close to 500awhp then you have to lengthen the front pipe to accomadate the extra block height etc lil stuff adds up Probably does already have the wide crank drive. I was talking about a cheap build, not a 10k build. I wouldn't be skimping on tensioners if it was a 10k build.. because a few hundred dollars in the grand scheme of things, is nothing. You don't necessarily have to change front pipe lengths etc, if there was enough clearance to the floorpan to begin with then it will more than likely be fine as 38mm at an angle over the length of the exhaust (from last hanger to firewall) will probably be sufficient. I didn't need to alter my exhaust at all -5's don't HAVE to make 500awhp, the guy was looking for a figure of about 400hp which can be done without going to the 10k build extents. I suggested the -5's that are for sale because for 2.4k, it's a pretty bloody cheap bolt on turbo upgrade for the 26. OR, to keep it cheap (meaning, not having to buy Jap stuff), 30 bottom end, highflowed turbos or some N1's if you can find them. After having experienced a few twincam 30's now (and having one myself), I just feel that if you ARE going to rebuild, then a 3L bottom end is a no brainer! Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4429918 Share on other sites More sharing options...
gazza750 Posted February 17, 2009 Share Posted February 17, 2009 i will be happy with a 2.8 stroker kit Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4430004 Share on other sites More sharing options...
bubba Posted February 17, 2009 Share Posted February 17, 2009 lol, my mate got a HKS 2.8 kit when our dollar was really good and even then it was crazy $_$ heh Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4430023 Share on other sites More sharing options...
R32 Driver Posted February 17, 2009 Share Posted February 17, 2009 but if your paying for a rebuild machine work and labour is half the cost already do it once do it right if on the other hand you can do it urself then i guess on the cheap is viable as u dont have to pay for labour when/if it blows up thats how i see it anyway Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4430151 Share on other sites More sharing options...
bubba Posted February 17, 2009 Share Posted February 17, 2009 (edited) but if your paying for a rebuildmachine work and labour is half the cost already do it once do it right if on the other hand you can do it urself then i guess on the cheap is viable as u dont have to pay for labour when/if it blows up thats how i see it anyway Yeah but you don't have to go a 10k build just for the sake of it.. people have budgets and they have to work within those budgets, if that means not getting a $2k oil pump because you don't *need* it, then don't get it. That's the way I see it, if it's not needed for the levels you want, then why waste the money when it could be better spent elsewhere? Track levels are not street levels, as I have said a few times, the cost of a build is directly proportional to the power goals and the intended usage Edited February 17, 2009 by bubba Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4430215 Share on other sites More sharing options...
R32 Driver Posted February 17, 2009 Share Posted February 17, 2009 10k is still a fairly basic rebuild (rb26) last time i got quoted 5k for machine work, labour and R&R still be using a N1 oil pump ~$500 these days i do agree to build a car for whatever goal you set out to be no point overkilling it but if he wanted 400hp wouldnt a set of -7 be better? more responsive so to speak Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4430675 Share on other sites More sharing options...
bubba Posted February 17, 2009 Share Posted February 17, 2009 Probably would be but can they be had for 2.4k? I only suggested the -5's as someone has a pair for sale for (what I think) is a reasonable price Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4431628 Share on other sites More sharing options...
R32 Driver Posted February 18, 2009 Share Posted February 18, 2009 CRD have them for $2490 a pair (-5) a new pair of -5 is only $2545 + delivery or same pricing for -7 from Sliding performance Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4432255 Share on other sites More sharing options...
bubba Posted February 18, 2009 Share Posted February 18, 2009 Oh, well there you go. I must have been thinking of the HKS kits Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4432289 Share on other sites More sharing options...
nism0man Posted February 18, 2009 Author Share Posted February 18, 2009 (edited) cheers for the input guys. i'll give c red a call about that rb26-30. my car has done about 125000 kms for those who are wondering and i was just driving normally when it happened and BOOM there was no power when i was giving it throttle so i pulled over and when i listened to it idle it sounded like marbles in a tin can being shaken around. then it slowly died. you guys have been really helpful btw how much is a r34 motor and where can i find one?. Edited February 18, 2009 by nism0man Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4433538 Share on other sites More sharing options...
gazza750 Posted February 19, 2009 Share Posted February 19, 2009 (edited) or take this option Brand New Modified Nissan R33 GTR N1 Engine - Nissan Skyline GTR Professionally Assembled - 500PS Package Our price: AUD 23000.00 http://justjap.com/store/home.php?cat=334 Edited February 19, 2009 by gazza750 Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4434023 Share on other sites More sharing options...
nism0man Posted February 19, 2009 Author Share Posted February 19, 2009 haha now that is way to expensive....could get another gtr for that Link to comment https://www.sau.com.au/forums/topic/257109-so-my-motor-blew-up/page/2/#findComment-4435688 Share on other sites More sharing options...
