Tony Quin Wins Rally Tasmania
Wogboy
 Share
I saw this car in action yesterday. it is unbelievably quick. But it is very hard on brakes, the officaials at the end of the stage said it was the onlt car to have glowing rotors at the end of the stage. And the once gold calipers have turned a poo brown colour because of the heat. I'll be interested to see how is lasts Targa Tas (esp if it's got proper rubber by then).
oh and it was the best sounding car in the field. only thing that is better is the lambo's (which weren't entered)
Edited by sav man
The Lambo's and maybe the Daytona's - but the R35 is right up there for sure.
Buggered if I know how to embed a video so here's a quick link to Tony's car in action -
Not sure if this was on the same set of tyres he used for TWP but if so it is even more impressive given that will be 3 tarmac rallies he's done on the one set of rubber.
Yep, big congrats to Tony and Naomi! Excellent result, it was close all weekend, but I'm glad that my winner prediction was correct :laugh:
Hey, will you and the Hi Octane GTR be here for Targa?
Hi mate. Yes, Russ will be there in the Hi Octane gtr.... I was going to nav for him but have decided to drive my own car.
35's should be thick on the ground! :laugh:
Good to see a Skyline get up there and win for Nissan.
But i hope this isnt taken as a negative thought or in anyway taking away from their achievement but this could almost mark the day that Skynet starts to dominate rallying...
I can't see how any of that could be taken as negative Roy?
I don't have an issue if a particul car tends to dominate rallying as such, and I believe that just about any front running car can have its day, given conditions that suit it and a crew that is prepared to push really hard, and possibly bin it
I was watching the times all weekend, and have no doubt that both Jim and Tony were both pushing very very hard, and also that the conditions really suited their particualr cars.
Remember that this was a short event, with no limit on tyre changes (did Tony Quinn even change one? :laugh:) and it was also dry. For those two guys to have such a big gap on Vandenbergs and Longhurst (3rd and 4th) is a real feat!
Congratulations to Tony and Naomi (my future sister in law) for winning this event and i hoe to see alot more wins from them this year yet as they have alot more races coming up this year.
It is great to see the GTR really starting to show its true colours and Tony is still learning the car so hopefully better things are still yet to come.
Look forward to catching up with both of you when you come through Burnie!
Remember that this was a short event, with no limit on tyre changes (did Tony Quinn even change one? :)) and it was also dry.
There was definitely a tyre changed involved - Quinn's fronts were worse than shagged on Saturday night!
It was brilliant to see Tony and Naomi take the win - Jimmy was a man on a mission this weekend and they had to fight for every second they got up on him and Barry.
We pulled up next to Tony after the last stage to offer what we hoped were to be their first lot of congratulations- even then he wasn't sure he'd done enough to keep Jim from first - it was just that close.
The 35 is absolutely going to dominate tarmac rallying once the tyres get properly sorted.
Awesome results!
And what of the tyres, is there anything on the radar?
Yeah, was running Dunlops day 1 and Bridgestones the rest? Judging from the photos ...
Bloody awesome work on the Bridgestones.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
