not sure what bearing....
But they said the head would need a recon or freshen up etc just by the sound of it, if that makes sense...
and also said even if the crank can be saved it would be over $500 to have it tidied up etc
The head might need to be decked and cleaned out but thats all unknown until it gets pulled out..Not major they just shave the bottom of it where it sits on the block for the head gasket..
Is this your first rebuild?
If you're mate is a mechanic I would get him to pull the engine out and open it up and see how bad it is..Go into the build threads here on SAU in the motorsport section and forced induction.
You have to look at it before you do anything...how loud was the knock?? how long has it been knocking?
  • Replies 60
Cheers mate.
Yer he will have a look in beofre i do anything... Im just working on worst case scenario...
It was knocking BAD BAD not for to long tho as when i worked out what it was i traliered it everywhere.
Yer id rather not rebuild as i need to sell. and trying to come away as cheap as possiable...
Easy as pie. Fill in the forms with new engine number, they then check that the engine didn't come from a stolen car and that's it. Mind you the last time I did it was around 6 years ago and they reprinted my rego papers to reflect new engine #
simple logic really.
you have a engine in your car that most likely has spun a bearing.
can you drive the car? No! so pull the engine out.
why trailer the car everywhere and get people to listern to it? thats a waste of time and money.
surely you can hear the noise yourself and know that it neads to come out and be stripped down.
and you have a mechanic mate thats prepared to help you,
so why is the engine still in the car?
its a 3 hr job to remove the engine, put it on a engine stand and pull the sump off.
you will then know what has happened and the cost of what needs fixing.
if everything is rooted then strip the good parts and get a stocker and bolt it back in.
if damage is minimal then take the crank to chris miltons get them to machine it new bearings and go again.
either way the engine has to come out. so thats allways the first thing to do.
Exactly what I said..But it is scary for the people that are used to this sort of work :)
Also why does everyone think a GTR rebuild is $10K?? That with expensive parts and for high power...
Nope. It's a common misconception. People hear 10k, then tell the next person, etc.
5k will get you a full rebuild with standard parts. 10k is something that will handle 300-400kw+
6-7k is a forged build with oil mods which will handle very decent power.
Unless you're thinking... Jun stroker kit or something... which is like $15k+ all up
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
