  • Replies 60
Nope. It's a common misconception. People hear 10k, then tell the next person, etc.
5k will get you a full rebuild with standard parts. 10k is something that will handle 300-400kw+
6-7k is a forged build with oil mods which will handle very decent power.
Unless you're thinking... Jun stroker kit or something... which is like $15k+ all up
Exactly it can be even cheaper if you pull the engine out yourself and you buy the parts that you want to put in it..
Yer true.. but im also looking at it for like ummm speed.. like itll be quicker for us to rip it out and put one back in.... Then to wait to have something rebuilt etc...
If i didnt need a house i wouldnt have worried about the moeny and rebuilt it with new turbos... nearly did it to be honest...
i just rebuilt my RB25 (same prices, parts and labour as 26) with Arias forgies, genuine main and big end bearings, N1 oil pump, new water pump, nismo thermostat, gates belt, cometic gasket, and custom sump. Had block decked, honed and washed, head faced and acid washed, nad crank linished.
It cost me just over 5k, but i put it together myself. It took me a week to do this. By the time the engine gets here from perth you can do a mild rebuild. Pull the motor out one weekend, send crank to get machined/linished, get a set of main and big end bearings, put together following weekend. Drive to work monday, no run in required, $2000 max
i cant see how new bearings (you'll get main and big end for under 400) and a crank linish/machine, would cost more than 2k. if you wanna get rid of the car thats all id be doing. parts total might be 700 or so, assembly might be a few hundred but if you have a mechanic mate shouldnt be an issue
Assembly is around 1500 if you wanted someone to build it for you. If you have a mechanic mate shouldn't bee too much trouble. But like i said, if you just wanna get rid of it, do bearings and fix the crank up, throw a new head gasket in and you're off.
If someone was to put the bottom end together for you and you just fit the headgasket and head i dont see it costing more than 2k, maybe 2.5k.
Like i said, my rebuild cost me over 5k, machining cost me $450, the rest was parts, see what im getting at
was hoping this weekend.. but the guy selling the engine is being a bit slow... Oh and my mechanic has had a hernia op and i cant rush him to soon! so mayb next weekend now grrrr... just dragging on...
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
