  • 3 weeks later...
  • Replies 42
I have added 3 pistons to my list today...
Started to breath into the dry sump tank heavily and once we stripped it down found 2,4 and 6 have melted away the ring lands
Not sure of the cause yet but will be checking injectors etc before blaming anything else.
Yeah I only did 10 laps in total. Really annoying as it had good pace in the morning, with more to come.
There's always next weekend....
Ill get another set of slugs and have it back together and running by saturday night. Just need to find the cause, so far all the data is showing everything to be reasonable. But number 3 EGT is slightly higher than the others which is also the piston it melted.
oh yeah I remember 2 other things I needed to add to this thread.
tubro
I recommend removing all nuts and washers from the inside of your intake, this one cost me a motor (spun bearings and scored bores)
and an transfer case. I snapped the chain. I'll post pics later it is a pretty amazing acheivement.
Brad it might be your thread but you still need to post pics....
Ill put photos of the piston up tommorrow. There at the machinists but ill get them back tommorrow with all the other stuff.
That turbo is fairly rooted! Ive also been through a fair few turbos and my current ones are pretty average too.
Na the piston didnt do any damage other than to itself really. We have checked the valves and head. There is a few cosmetic marks on the squish bands but nothing that wont clean up with a surface grind.
Small mark on the bore which is a deposit not a score so it will be lightly honed and reused.
Pistons will be done tommorrow, set of rings, bearings and gaskets will see it back in action.
Sam was here tonight checking everything else out engine wise and the injectors are being tested tomorrow as well.
Ill use this engine again for a few meetings and re-block it when we have a 3 week break and I have another block preped ready to go.
The turbos are more so damaged due to the lack of air filters and dusty circuits we race on. Its something i've been trying to get sorted but driving the car has become priority over making up and intake, kinda backwards really but oh well....
Best photo I currently have, there is about 80%of the top ring land gone and its burnt all the way down the skirt.
tubro
I came sooooo close to that one myself Dunc. Got home from a cruise on sunday and popped the bonnet for a quick look see and crapped my pants when I saw one of the backing plate bolts was missing from the air cleaner.
Knowing that there was a nut on the inside of the filter made for some heart in mouth stuff while I took the filter off.
Huuuuuge relief to find the nut laying in the bottom of the filter.
One redesign coming right up.
tubro
The Turbos i had on my car when it came from japan were like this, I didnt know untill i changed the dumps 2 years later.
it still made 360something hp and i thought it went sweeeet.. then got the turbos repaired and woahhhhhh massive difference..
and now engine pop :) and i'll finally post that photo :)
My bottom end is all assembled again!
Ill be chucking a head back on it tomorrow and will be sweet to go again.
Block is a little average now and Piston to bores are 1/2 thou over what they were last time but oh well.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
