  • 3 weeks later...
  • Replies 42
I have added 3 pistons to my list today...
Started to breath into the dry sump tank heavily and once we stripped it down found 2,4 and 6 have melted away the ring lands
Not sure of the cause yet but will be checking injectors etc before blaming anything else.
Yeah I only did 10 laps in total. Really annoying as it had good pace in the morning, with more to come.
There's always next weekend....
Ill get another set of slugs and have it back together and running by saturday night. Just need to find the cause, so far all the data is showing everything to be reasonable. But number 3 EGT is slightly higher than the others which is also the piston it melted.
oh yeah I remember 2 other things I needed to add to this thread.
tubro
I recommend removing all nuts and washers from the inside of your intake, this one cost me a motor (spun bearings and scored bores)
and an transfer case. I snapped the chain. I'll post pics later it is a pretty amazing acheivement.
Brad it might be your thread but you still need to post pics....
Ill put photos of the piston up tommorrow. There at the machinists but ill get them back tommorrow with all the other stuff.
That turbo is fairly rooted! Ive also been through a fair few turbos and my current ones are pretty average too.
Na the piston didnt do any damage other than to itself really. We have checked the valves and head. There is a few cosmetic marks on the squish bands but nothing that wont clean up with a surface grind.
Small mark on the bore which is a deposit not a score so it will be lightly honed and reused.
Pistons will be done tommorrow, set of rings, bearings and gaskets will see it back in action.
Sam was here tonight checking everything else out engine wise and the injectors are being tested tomorrow as well.
Ill use this engine again for a few meetings and re-block it when we have a 3 week break and I have another block preped ready to go.
The turbos are more so damaged due to the lack of air filters and dusty circuits we race on. Its something i've been trying to get sorted but driving the car has become priority over making up and intake, kinda backwards really but oh well....
Best photo I currently have, there is about 80%of the top ring land gone and its burnt all the way down the skirt.
tubro
I came sooooo close to that one myself Dunc. Got home from a cruise on sunday and popped the bonnet for a quick look see and crapped my pants when I saw one of the backing plate bolts was missing from the air cleaner.
Knowing that there was a nut on the inside of the filter made for some heart in mouth stuff while I took the filter off.
Huuuuuge relief to find the nut laying in the bottom of the filter.
One redesign coming right up.
tubro
The Turbos i had on my car when it came from japan were like this, I didnt know untill i changed the dumps 2 years later.
it still made 360something hp and i thought it went sweeeet.. then got the turbos repaired and woahhhhhh massive difference..
and now engine pop :) and i'll finally post that photo :)
My bottom end is all assembled again!
Ill be chucking a head back on it tomorrow and will be sweet to go again.
Block is a little average now and Piston to bores are 1/2 thou over what they were last time but oh well.
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4. Luca Stamatescu 5. Tony Buckland 6. Min Chan 7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
