hi there guys, i just bought my r34 gtr vspec its got the on board digital computer it seems to get hot every time i give it a fang the temperature reaches 105 but when im cruisin it sits between 90 and 98 is that ok or is there something wrong and the car is completely standard thanks
https://www.sau.com.au/forums/topic/257158-r34-gtr-v-spec-over-heating/
If you're the 1st owner in Oz, it is 'best practice' to replace the Jap water/coolant and replace it new stuff. This policy can save you from a new radiator, heater core etc. This is the start of your process of elimination. Congrats on your new acquisition!!!
^^Good stuff!
I use Tectaloy 100 radiator coolant, which is pre-mixed and designed for Turbo cars.
Also if you want to enhance your cooling in the engine bay, you can install a R34 GTR V-Spec II carbon fibre bonnet as they have a NACA duct positioned above the twin turbo system and it would give you extra cooling.
They are a straight fit bolt on.
Unless you have a V-Spec II than all is good...
There are a couple of different rating thermostats available, one of which will do that. Certain BMWs capitalise on the availability of these too.
And since you've already changed the coolant, you didn't forget to bleed the remaining air out did you? Your temp will go up if there's any air left in there.
would a 52mml alluminuim core raidiator keep it cooler or keep the temp lower than standard raidiator???
Doubt it (refer latest HPI)
Isn't 98 a bit hot for "cruise", ie low load? That would suggest a problem with the water pump - occasionally the vains rust away and it can't circulate coolant as efficiently.
If you upgrade your radiator, it will help with cooling, but if your not doing any serious track work, there is not much point... But dosen't hurt to change it either.
You might want to check your water pump, but I doubt it will be the problem.
On a hot day, your temps will always sit alittle higher then on a cooler day.
I would keep a look out for your oil temps too... Does it go up like your water temp or is it sitting at a regular temp?
I dont see any higher thatn 83-88 for water temps (on a 38 degree day it reached 90 but i put the heater on the bring it down)
oil temps are about 81 on a cold night and go as high as 85 on a hot day cruising but ive never seen higher than 90degrees ever
From memory thats seems fine on a hot day as my car can get to those temps too. + it depends if you run your A/C or driving up a hill, anything that requires the car to be rev'd alittle harder with effect the temps. Again its normal.
Normal crusing temps are just under 90 degrees.
From my understanding, the R34 GTR's seem to hold quite a consistant temp, even with a bit of a fang.
My friend Tim GTR on SAU has a R34 GTR V-Spec, I took it out for a run, hammered it down the straight and a few corners, then check the MFD with the oil and water temps and they seem stable and yes within that range from about 91 to 98, I think it sat at about 93 degrees C.
What engine oil you using?
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
