  • Replies 43
sven laptop ... i'll be around fairfield most of the time getting my R32 done at BMT Motorsports .. and my Green Ceffy will be registered by Tuesday.
So .. the Green one will be Fairfield general area most of the time .. the white one (camber king) is parked in Heidelberg atm...and the Black one is at my parents around Mentone area.
buzz me if your an interested potential buyer :P
0421 025 259
regards,
Oyabun
No - the car is good. Only loud when it needs to be. The white one is really quiet - I was very surprised.
They are very unassuming too, at first glance you think its a lowered Camry. I followed the green one for a while and it looks tough. The steep rake on the rear screen and fat tyres really look good.
hey sven laptop,
The green one is registered this week, and the white one can be prepared for registration in approx 2 weeks (I still need to comply it), but this is no trouble at all.
It is very quiet indeed ... you would be surprised!
The Rims you can keep however I will change the rims with silvia for the time being. This would be perfect with some deep dish all round.
*bump*
nice ceffys dave.... like the look of the black one... unless the green ones pic quality is just poorer. Good luck!!
thanks inark ..
just checked mail and got 2 enquiries .. one seems quite serious.
driving around in the green one now ... lots of fun as i had 4 friends cruising through city with exhaust and bov walng away .. cops dun even think the sounds come from the cefiro ... they are looking for the skyline :) ..
seriously pimp .. not as cool as a chev impala ('sup ash ;) )
cheers Jamezilla...
Many are seeing the light of the great Cefiro...
thanks champ, I'll contact her.
Seems to be a lot of interest now ... just waiting for the first concrete offer on one of them. I've had a few offers for 'trade ins' :)
cheers,
Oyabun
  • 4 weeks later...
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
