Having a clean up to in order to move. PM me if you have any questions.
I am located in Burnie, Tas
Standard R34 GTT FMIC
No damage - removed for FMIC fitment - Includes factory pipe pictured
$140
Standard R34 GTT Wing with East Bear Pillars
Great Condition - Removed for shaved boot - Painted Jet Black - Fully adjustable- Made From Aluminum
$220
post-48970-1234689349_thumb.jpgpost-48970-1234689383_thumb.jpgpost-48970-1234689412_thumb.jpgpost-48970-1234689514_thumb.jpg
R34 GTT/GTR East Bear Bottom Eyelids
Like new condition - ABS Plastic - Painted White
$80
R33 GTS-t Series 1.5 Turbo
Very Minimal Shaft Play - Removed from engine with 33,000Klm's - Removed due to blowing slight smoke most likely oil seal wear - Great for High Flow project or oil seal replacement
$150
R33 GTS-t Series 1.5 Radiator and Surround
Great Condition - No Damage
$80
Trust AIRINX Pod Filter
Almost Brand New - Used for maybe 1000Klm's - Washable Filter
$55
Edited by SLY034
https://www.sau.com.au/forums/topic/257165-garage-sale-r34-r33-bits/
Dimensions of the wing dude?
Overall Width 1335mm
Overall Height 300mm
Width between mounts 840mm
that looks bigger then a normal rb25 turbo?
Its not bigger. Its a standard turbo
R34 GTT Intercooler
R33 GTS-t Turbo
Trust Pod Filter
R34 GTT East Bear Bottom Eyelids
ALL still up for grabs. Dont be scared, make a pm offer. Nothing silly, just want this stuff gone. :(
$80 including postage???
any chips or marks???
They are like new. One very very minor mark on one you cant even notice (im just picky). 80 including? Depending on your location. Whats your postcode?
Edited by SLY034
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
