Drift Comp March 7
sidewayssam
 Share
Aint driven my car on teh Dirt, :P Where can we all park that wont be taken, Pref not on dirt but aint fussed.?
I would normally suggest near cat corner opposite those race sheds, but i think they have RC Drift there on battle days. + they guy at the gate wont let u in.
I normally Grab 1 of 50 Cripple Bays, that are just before the gate/dirt as just about all of these fill up by the time the battle begins, they dont really care unless its like V8 supercars.
im always at the esses
just down from c-red corner,
under them big signs.
i'l be there with my deck chair, esky and "SOMBRERO"
woot woot
ric ur such a yobbo love it mate cya out there
Top effort today Sam
But my big thank you goes out to 2 dickheads driving white 33's around the back of CAT CNR
Thanks to those two RETARDS i now have to respray the front bar of my falcon as they had to be heroes and do their gravel burnouts as they were leaving and it sprayed all over the front of my daily
Edited by gazza750
Had a wicked day,
I had a few probs this in the mournin, I wasnt paying any attention and put to much oil in my engine :)
then i went out for a couple practice runs before my qualifiers but bouncing off the limiter for minutes at a time filled up my oil catch can in turn coating my engine bay and windscreen in oil :D
i nearly was disqualified due to the oil spill, i then put a gatorade bottle over the catch can over flow :D
only just got out in time to do 2 qualifiing runs and managed 5th place,
i then versed Dim in the Silvia and won but then lost to Lance Biffen,
I have some in car vids il put up later
 Share
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
    • It could be. It might not be. It is impossible to know without context by asking the owner or the tuner on the day and knowing what they were doing/not doing/attempting to do. You said earlier this is hard to understand because to your mind, a turbo is at full speed when it hits its spike. This is not true. The turbos actual speed is defined by how much air is being forced through it via the exhaust, unless you control it. The spike you are seeing at ~whatever RPM it 'spools' at, is where boost control is starting. If there were no boost control the turbo absolutely would be spinning much faster at 7000rpm than 3000rpm, every single time, on every single engine. Boost control keeps the boost controlled within the limits you ideally want. If it were uncontrolled you would have two scenarios 1) You have a turbo that hits peak RPM and CFM (not boost) at the redline of the engine. This would work, but most people want more boost earlier. 2) You have a turbo that hits peak RPM well before the redline of the engine (say, 3500), and you explode the turbo by redlining the engine. (say, 7000rpm). If you don't want exploding things, or lag, you design a turbo system to come on when you want the boost to be useful, and then not overspin itself into oblivion by using some form of boost control, to control the boost pressure accordingly.
    • Yep. >10 posts required. Prank can relax that for individuals when required.
