Hi all,
Im at the final stage of building my RB30/25. .
I was going to use the RB25DE pistons however shaving 2mm off the block equates to a 4% loss in torque (Torque= Force x Distance). . and being an N/A I want all the torque I can get :)
I have opted to get a set of custom Hyper Eutectic pistons made, that way I can get valve notches cut into them and bore the block 30thou oversize. .
Bottom end is a linished crank, spool rods with arp rod bolts, hyper eutectic pistons, acl race series bearings for both big end and mains. .
This is all fully balanced with the flywheel and pressure plate. .
The head is a R33 head with VCT (Not sure if it can be used with custom cams?).. I am having it serviced and then when it is serviced I am going to have it re assembled with stiffer valve springs (if needed, not sure yet) to suit the cams. . Hopefully in the 270degree and 10mm lift range. .
So my main question is. .
What spec cams should I get? I understand that lift is for torque?? and duration is for. . . .? Note: I do not want to convert to solid lifters.
And then, my head is going to cc in at about 50cc, in the hope to get into the 11:1 comp range. . If I have cams with say a 10mm lift, how deep will the valve notches have to be to clear the pistons (0 deck height)??
Thanks all,
Josh
https://www.sau.com.au/forums/topic/257270-what-cams/
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
