Yeh i know the common thing to do as simply get a z32 afm it would work fine yeh, but the advantages ive thought about is the added pod so less air rescrition.
on the apexi s-afcII you can have it calc having two inputs but only sending one signal out. so that shouldnt be a problem either.
the bit im not sure about is how would i go about wiring a second afm into my car. if i had a plug and joined the matching wires would this work? i myself cant think of any reason why this wouldnt but im hoping someone else might be able to share some light on the matter.
thanks.
https://www.sau.com.au/forums/topic/25728-adding-a-second-afm-onto-gts-t/
so i would have to connect the 5v, the earth then run a new wire the to s-afc for the signal out and then leave the signal ref blank. in theory. this should work. as long as both afms are the same type. ?
set the afc to 2 inputs and ave for the single output.
