Here are all the goodies to get the hp out of your skyline,I recently brought most of these parts brand new for the build on my Rb25det in my R33 ser2.but now i need the money so selling it all. contact me on 0422 361 904 or on here cheers jack.located on the gold coast.
New Haltech E11 V2,Rb25 patch loom,RB25DET fuel map,air temp sensor,3bar map sensor,lap top dongle,start up guide and software CD.
Paid $2335 sell for $2150 with receipt from haltech.
New CPC Custom Plenum Creations,This plenum is custom made by cpc specially for RB25s,designed in house and computerised flow tested to ensure the best efficiency.has the plate on the rear for an iac valve has not been tapped or drilled so you still have the option not to run it,and all the vac holes are tapped on the bottom along with fittings.Throttle body flange is for standard rb25 throttle body direct fit.
Paid $880 sell for $820
Second hand Garrett GT35R ball bearing turbo,polished .70 compressor housing, .63 exhuast housing.comes with braided oil and water lines with speedflow fittings for the block too.all to suit an Rb25 top mount manifold setup.also comes with an original garrett turbo blanket.this turbo only did 10,000 kms no shaft play practically brandnew, $1200
New magna fuel reg with liquid filled turbosmart guage,steady pressure upto 700hp
paid $340 sell $300
New 6 X siemens 870cc 14mm Top feed injectors with O-rings
paid $540 sell $500 with receipt from injectors online.
New 14mm Billet fuel rail
paid $150 sell $100
Second hand 45mm Turbosmart progate,with V band clamp onto manifold unsure what spring tension.
sell $400
New HKS super fire spark plugs,Iridium and platinum,to suit rb25det M35i
paid $180 sell $150
New K & N pod filter 4"
$60
New vac block $80
Second hand standard R33 series 2 fuel pump
$60
Second hand Drift oil catch can with bracket $40
post-32953-1234791555_thumb.jpgpost-32953-1234791651_thumb.jpgpost-19795-1124701954.jpgpost-32953-1234791781_thumb.jpgpost-32953-1234791841_thumb.jpg[
attachment=207015:IMG_0026.JPG]post-32953-1234791959_thumb.jpgpost-32953-1234792017_thumb.jpgpost-32953-1234792079_thumb.jpgpost-32953-1234792158_thumb.jpg[at
tachment=207020:IMG_0001.JPG]post-32953-1234792285_thumb.jpgpost-32953-1234792353_thumb.jpgpost-32953-1234792417_thumb.jpgpost-32953-1234792484_thumb.jpg[atta
chment=207025:IMG_0012.JPG]post-32953-1234792607_thumb.jpgpost-32953-1234792668_thumb.jpgpost-32953-1234792728_thumb.jpg
https://www.sau.com.au/forums/topic/257344-r33-sii-rb25-performance-parts/
would love the plenum dude but can't really afford it at that price.
If you get desperate and are willing to come down a but more (circa 600 ish) then i'd be more than willing to take it off your hands. I know its worth more i ain't low ballin just can't afford that much right now
cheers mate!
