Have just discovered i have a broken weld on my R33 clutch pedal box, car is still drivable but means i have about and inch of clutch pedal movement and is of course going to get worse by the quick look i had under the dash it looks like a side strut support that keeps the pedal straight.
Is it possible to pull clutch pedal box out with out pulling out the dash?
is it a common problem and if it is what have other people done to fix it?
https://www.sau.com.au/forums/topic/257433-clutch-pedal-box/
I converted my R33 GTS-t from auto to manual, so had the whole pedal box out to fit the 3 pedal set up, and didn't remove the dash. I THINK I removed the steering column, or at least loosened it to allow me to gain better access. It was no big deal, took about 2 hours including hole sawing the bulkhead for the clutch master cylinder. I did remove the lower access panel of course.
if anyone else comes across it, it is pretty easy to repair remove the pivot/lock pin from the clutch master cylinder - clutch pedal then undo the 2 nuts on the master cylinder and the one 12mm that bolts through into the top of the fire wall under the dash and wiggle the pedal box free
Liverpool exhaust charged me 30 bucks to weld it up and i refitted it took me about 2 hours all up incuding welding.
looking at the design of the clutch pedal box i would say its fairly common.
yep, it's common. and they are easy to remove/replace. I swapped mine out for the nismo one a few years ago and the creaking (impending doom) went away. :P it's easy to reinforce the stock one too with some strategic welding and a few bits of scrap metal.
I've gone thru 3 clutch pedals with the last one not only breaking but the whole frame was warped which changed the alginment of the pedal as you push it down. Got another replacement and welded the f*ck out of it with extra bits of metal. probably doubled the weight but it ain't breaking now :P
oooh my clutch pedal has always made a creaking sound when I push on the pedal, I thought it was just the bearing or some such.. but it could be on the way out? I remember at one point getting so annoyed it chucked some WD40 on it and it went away for a little while.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
