Hi guys, I'm going to do the driving test this Thursday, but I'm still very confused with some road rules. Can you guys help me out? Thanks in advance. Please have a look the attached picture for the questions.
Q1: I'm driving in a single-lane road (one lane on each side of the road), which has a bicycle lane on my left. Do I must change lane into the bicycle lane before turning left? ps. the bicycle lane is wide enough for driving and cars can also be parked there. how about if it's a parking lane?
Q2: I'm driving in a single-lane road. Suddendly, the road ahead is divided into two lanes, do I have to signal before enter either of them? If so, how?
Q3:I'm driving in a two-lane road (two lanes on the side of the road I'm driving in). Suddendly, the lane marking lines disappear(merging into one lane), do I have to signal before proceeding? If so, how?
Q4: I'm turning right from road A, which has only one right turn lane, into road B, which has three lanes on my side. Am I allowed turn into either of the three lanes, or only the right lane?
Thanks in advance,
Ollien
Edited by ollien
https://www.sau.com.au/forums/topic/257441-about-some-road-rules/
Q1 - No you dont hav to indicate for either
Q2 - Yes you should indicate left and go in the left lane.
Q3 - Yes you have to indicate, if the lane ends to the right then if you are in the left lane you have to indicate right and vice versa.
Q4 - Yes you can go in any lane you want, but if you dont need to be in any particular lane then stay in the left one.
Thanks and3_3. But my first question is about lane change. I wonder if I must change lane (bicycle/parking lane) before turning.
by the looks of the other traffic in the pic, you need to move left (indicate) when safe and turn. as for q4 i think you need to go directly into the right lane then indicate left across to the lane you need to get into.
Edited by Pal
I'll start by saying I completely disagree with the first poster who answered questions, so I'm going to re-answer.
EDIT: just saw your image attachment, nice :ermm:
Parking lane? The car parking spots will end before the intersection allowing you to move to the left.
Yes, there is a break in the bicycle line before the intersection where you move in before you turn left.
On the parking lane picture, there is a line showing where the parking lane ends, you follow the curve when turning.
On the bicycle lane example, there is a break from where you can start pulling to the left (30m probably) to perform your left turn, in your picture example there is a car already doing this).
You certainly don't stay where you are and then suddenly turn left across the bicycle lane, you might kill a cyclist :)
No, you merge into your chosen lane, my driving instructor taught me this, I got told off for indicating, what are you indicating? Your not changing lanes unless you wait until the divided lines appear next to you, if you do then you indicate as per normal.
Merging does not strictly require indication, it is sometimes done for courtesy.
I'd say no.
Since you are the only right turning lane, you have a choice of the lanes on the road you are turning into.
Good luck
Oh, got my license 6 years ago for the comparison ;)
from memory for Q1. you cannot change lanes into the parking /bike lane unless it has broken lines. the broken lines will appear before a street for you to indicate and merge into for you to turn. You can even see where the solid line ends and broken begins just before the turn in your pic. broken lines means you treat it as another lane so you must indicate regardless. I remember my instructor throwing this one at me and catching me out.
He said to always take notice of the lines on the roads whether theyre solid or broken to give you an indication as to what you should do. Same goes with when your driving out of a street with a service lane onto a big usually multi-lane road. You will notice a stop sign when you approach the service lane, then a pair of dashed lines after to get onto the multi lane road. treat the dashed lines as give way signs and slow down and be cautious even if there is no traffic. Same applies when your turning off the main road into a street with a service lane. He caught me out on this one too. Never encountered these situations in the actual driving test but its good to know.
Many thanks for the kind replies.
So far, I feel it's clear for Q1 & Q4 as most of you agree to each other. But obviously there exist different opinions about Q2&Q3 regarding signal when merging/diverging. I probably need more suggestions to draw a final conclusion and practise it in my driving test.
Thanks again.
Ollien
Q1. As others have said.. with the broken lines you can merge into bicycle/parking.. however you need to indicate..
Q2. When the lane splits into two lanes straight in the middle of your lane (as indicated.. you are not required to indicate but i also would stay left as there are usually signs marked (in qld anyways) "keep left unless overtaking".. hence why unless you are turning in that lane i would keep left
Q3. Again as said, you are not required to indicate unless you are merging into their lane.. ie your lane is closing... however as your lanes are merging together it is not necessary to indicate
Q4. Either lan is ok, as there is no 'guided dash lines' as you can see in other lanes turning.. so you have your choice of lanes unless you are required to follow the path given..
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
