Lads.
Got a real tidy r33 gts25t series 2. When it was bog stock i had it dynoed. Made 157kw ATW.
Ive since installed r34 SMIC, 3 inch Catback Nismo Exhaust (high flow cat included). Reckon its fairly safe to give it another 2psi (with a decent dual stage controller) and a retune?
When they initially dynoed it the AFR's at high revs sat between 10 - 10.5? Is this ok?
Any advice is appreciated. I love the car, want to get a few more kilowatts without going nuts with front mounts etc etc.
Cheers,
Matt
https://www.sau.com.au/forums/topic/257449-r33-gts25t-any-advice/
what exactly are you tuning?
should invest in a dump/front pipe, which should see you pick up a few more kw.
been told if im not highflowing the turbo or running high boost there is no point getting turbo back exhaust. probably lose a fair bit of low end torque?
Im no mechanic to be honest... Running 10spi hurt her? Would i notice much of an increase. Exhaust did a little revs better. Looking for around 200 ATW ultimately
Check the RB25 upgrade thread up top^^^^^plenty info there.
My car for example was the following.
152rwkw cat back zorst 11 psi
174rwkw 3 inch dump high flow cat 12psi (very good upgrade)
200 rwkw blitz FMIC and tune 12psi(standard computer massive dip around 5k)
202rwkw Power FC 10.5psi and upto 30rwkw better in the mid range.
All done on the same dyno. Hope this helps good luck with it.
Bullshit, whoever told you that is an idiot. The exhaust is the most restrictive part on these cars, doing a dump pipe upgrade (and a cat upgrade) is probably one of the best bang for buck mods that you can do. My car was stock with just a cat-back when i bought it, the dump pipe/cat was one of the first mods we did and it really woke the car up making it feel better throughout the rev range.
10psi will be fine, just make sure your plugs/coilpacks are up to scratch so you don't have missfire problems.
Excellent. Front pipe it is. I can get my hands on a new Turbosmart Dual Boost Controller real cheap. Do the job for now? Coilpacks seem ok, no symptoms like anything ive read so far. last noob ignorant questions my apologies... (the input so far has been excellent cheers)
These POD filters ive seen, as opposed to the standard box with say an new HKS Filter thing, whats best? (im aware its apparently defectable though im not fussed to be honest). Its not going make the idle f**k up or anything like that? My mate had a r32 gtst with BOV (which i wont be upgrading) and pod filter etc nice car buts its idle was all over the place and would stall at traffic lights all the time when coasting to a stop. did my head in... the R33 is used now as a daily driver
the r34 SMIC sufficient for 200ATW? I want to avoid FMIC.
thanks again
10 to 10.5 on the AFR is to rich, need to get yourself at minimum a SAFC2 or aftermarket ECU and get it up to 11.5 to 12. save heaps of fuel to. on 10 psi you'll be making around 180 to 190 rwkw wiith the mods you got. keep the stock air box and put a good panel in it
Edited by Pal
the stalling problem ur mate had, i would sway towards BOV. i have an atmo BOV and apexi power intake pod. had stalling issues before but since cleaning my AAC valve (check DIY) i have had no dramas at all.
if u want a nice sucking sound on boost then get the pod, if u want it to stay quiet under the bonnet then just upgrade the panel filter.
hope this helps
Edited by auss13
thanks again
not just the front pipe. dump and front pipe combo.
pod filters can suffer from heat soak, so in fact can rob you of power.
get yourself a decent high flowing exhaust from the turbo back, boost controller and a safc, and you should be seeing 200rwkw with your smic.
got a few extra buck, fark the safc off, and get a power fc instead. you will be better off in the long track.
I think the person who told you that you'l lose low end torque was slightly mistaken - Its the initial response you might lose. If you think about it, it makes sense, upgrading to a bigger dump means that theres just a little bit of extra volume to be filled by exhaust gases. You will not lose torque at all. More like it will increase your torque overall through out the rev-range.
Get a full trubo back zorst... not a canon drony crap but a twin pipe.
Bought a 3inch split dump/front pipe today. JJR. Im gonna give installing it a go today. wish me luck. im pretty handy with the tools generally and watched them do the catback install. it was a piece of piss. Any suggestions? Ive got no hoist with this cause a major difficulty?
Be easier with ramps or axle stands, if your going to get active with your car and do some of the work yourself then invest in ramps/stands. Ramps are probably a bit more stable and trustworthy, but stands are OK - I use both at different times.
[bTW I use a jack to lift the car and then slide my ramps under then lower the car back to them. The front bar is way too low otherwise]
rich is safe for the engine though yeah? just chews more petrol?
the jjr split dump and front pipe is a great mod....i got a series 2 r33 aswell mate.....got it bog stock like u...and my first mod was a full turbo back exhaust.....the performance increase was phenomenal...by the seat of that pants dyno, i really noticed it....i was tossin up between a pod and stock air box, but i jus got a k&n panel and went that way...safer, and flows jus as well....actually i find it works better than a pod.....
Guest jaysiin001
thats pretty good with 30kw in the mid range. might look into a new ecu as i have a stock ecu. got 187rwkw but feels too gutless down low. needs more power/torque
Tell your mate to get a hybrid BOV - Vents to atmo as well as plumbs back.
This will solve his problem.
Happens to most RB20's.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
