Lads.
Got a real tidy r33 gts25t series 2. When it was bog stock i had it dynoed. Made 157kw ATW.
Ive since installed r34 SMIC, 3 inch Catback Nismo Exhaust (high flow cat included). Reckon its fairly safe to give it another 2psi (with a decent dual stage controller) and a retune?
When they initially dynoed it the AFR's at high revs sat between 10 - 10.5? Is this ok?
Any advice is appreciated. I love the car, want to get a few more kilowatts without going nuts with front mounts etc etc.
Cheers,
Matt
https://www.sau.com.au/forums/topic/257449-r33-gts25t-any-advice/
what exactly are you tuning?
should invest in a dump/front pipe, which should see you pick up a few more kw.
been told if im not highflowing the turbo or running high boost there is no point getting turbo back exhaust. probably lose a fair bit of low end torque?
Im no mechanic to be honest... Running 10spi hurt her? Would i notice much of an increase. Exhaust did a little revs better. Looking for around 200 ATW ultimately
Check the RB25 upgrade thread up top^^^^^plenty info there.
My car for example was the following.
152rwkw cat back zorst 11 psi
174rwkw 3 inch dump high flow cat 12psi (very good upgrade)
200 rwkw blitz FMIC and tune 12psi(standard computer massive dip around 5k)
202rwkw Power FC 10.5psi and upto 30rwkw better in the mid range.
All done on the same dyno. Hope this helps good luck with it.
Bullshit, whoever told you that is an idiot. The exhaust is the most restrictive part on these cars, doing a dump pipe upgrade (and a cat upgrade) is probably one of the best bang for buck mods that you can do. My car was stock with just a cat-back when i bought it, the dump pipe/cat was one of the first mods we did and it really woke the car up making it feel better throughout the rev range.
10psi will be fine, just make sure your plugs/coilpacks are up to scratch so you don't have missfire problems.
Excellent. Front pipe it is. I can get my hands on a new Turbosmart Dual Boost Controller real cheap. Do the job for now? Coilpacks seem ok, no symptoms like anything ive read so far. last noob ignorant questions my apologies... (the input so far has been excellent cheers)
These POD filters ive seen, as opposed to the standard box with say an new HKS Filter thing, whats best? (im aware its apparently defectable though im not fussed to be honest). Its not going make the idle f**k up or anything like that? My mate had a r32 gtst with BOV (which i wont be upgrading) and pod filter etc nice car buts its idle was all over the place and would stall at traffic lights all the time when coasting to a stop. did my head in... the R33 is used now as a daily driver
the r34 SMIC sufficient for 200ATW? I want to avoid FMIC.
thanks again
10 to 10.5 on the AFR is to rich, need to get yourself at minimum a SAFC2 or aftermarket ECU and get it up to 11.5 to 12. save heaps of fuel to. on 10 psi you'll be making around 180 to 190 rwkw wiith the mods you got. keep the stock air box and put a good panel in it
Edited by Pal
the stalling problem ur mate had, i would sway towards BOV. i have an atmo BOV and apexi power intake pod. had stalling issues before but since cleaning my AAC valve (check DIY) i have had no dramas at all.
if u want a nice sucking sound on boost then get the pod, if u want it to stay quiet under the bonnet then just upgrade the panel filter.
hope this helps
Edited by auss13
thanks again
not just the front pipe. dump and front pipe combo.
pod filters can suffer from heat soak, so in fact can rob you of power.
get yourself a decent high flowing exhaust from the turbo back, boost controller and a safc, and you should be seeing 200rwkw with your smic.
got a few extra buck, fark the safc off, and get a power fc instead. you will be better off in the long track.
I think the person who told you that you'l lose low end torque was slightly mistaken - Its the initial response you might lose. If you think about it, it makes sense, upgrading to a bigger dump means that theres just a little bit of extra volume to be filled by exhaust gases. You will not lose torque at all. More like it will increase your torque overall through out the rev-range.
Get a full trubo back zorst... not a canon drony crap but a twin pipe.
Bought a 3inch split dump/front pipe today. JJR. Im gonna give installing it a go today. wish me luck. im pretty handy with the tools generally and watched them do the catback install. it was a piece of piss. Any suggestions? Ive got no hoist with this cause a major difficulty?
Be easier with ramps or axle stands, if your going to get active with your car and do some of the work yourself then invest in ramps/stands. Ramps are probably a bit more stable and trustworthy, but stands are OK - I use both at different times.
[bTW I use a jack to lift the car and then slide my ramps under then lower the car back to them. The front bar is way too low otherwise]
rich is safe for the engine though yeah? just chews more petrol?
the jjr split dump and front pipe is a great mod....i got a series 2 r33 aswell mate.....got it bog stock like u...and my first mod was a full turbo back exhaust.....the performance increase was phenomenal...by the seat of that pants dyno, i really noticed it....i was tossin up between a pod and stock air box, but i jus got a k&n panel and went that way...safer, and flows jus as well....actually i find it works better than a pod.....
Guest jaysiin001
thats pretty good with 30kw in the mid range. might look into a new ecu as i have a stock ecu. got 187rwkw but feels too gutless down low. needs more power/torque
Tell your mate to get a hybrid BOV - Vents to atmo as well as plumbs back.
This will solve his problem.
Happens to most RB20's.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
