Old School N New Age Show
MissR34
 Share
  • Replies 354
WOOOO about 6 White Cars :ermm:
Ill be at villis at about 7:45, so say sometime between 7:30 and 8pm. Ill fill the pay and fill the forms in this Friday. Hmmmm, now to go get some good car wash and wax etc etc.
mate let me know when your free , you can pop over to use my detailing goodies, buffer too. it'll shine up your ride like glass. takes a while but well worth it.
My mates entering his bike, so if I wasn't defected I'd join in.. oh well.
Have a look for a white R1.. 'UPON1'
Bikes can enter? Oops I missed that bit.
I should enter the Brutale with all the CF bits ... or my Rizla replica TLR1000 :)
do it ruby....that brutale is awesome mate
I'll have to see about getting it towed there.
Prob too hard anyway. I live near Regency area and getting two vehicles down south will be PITA.
lol just load the bike on the back of the volvo....i mean the stag ;)
The Stag isn't THAT big :) ... and I don't have any towbars on any cars :D
I've got the Brutale up for sale too, so sticking it in the show might be good.
Here are two lovely ladies promoting the Brutale:
Unsure if I'll have my TLR ready in time ... that'd be a good one for the show. I reckon it'd be the loudest vehicle (per engine size) there :bunny:
i've been asked to put my drift car on the back of some new towing business's truck for this.
the s13's butt ugly so i might not do it, plus i just notice that it's on my 21st bday so i wont even be here for it haha.
Edited by Import S13
don't sell the brutale :D
that thing is tuff ;)
+1. not a bike person but yeah, that brutale is hardcore... why selling that one and not yr other bikes? Too expensive to run/keep on the road?
-D
Im in guys, lost the semi final.
OH THATS GREAT DAMO
i mean..........sorry to hear u lost the semi final :D
Luke - ill be sending out a sms hopefully wed or thurs with all the info ;)
Yay, i can have the day off work to enter my car...now to find someone to cover for me :3some: .
Ah cheers troy, I'm off this Wednesday, ill send you a pm too.
 Share
    • Great write up. I was thinking abt getting the niftycity for my g37 the aliexpress links u shared r not working anymore. Can u share again please?
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
